Open Solidworks files Inventor 2016
Torben.pedersen
Message 1 of 12
Torben.pedersen
I have tried to open a prt. file whit Inventor 2016 but I get no part, when I try to open I get a blank inventor file, and open a browser whit an error.have anyone any solutions?
I hope this was helpfull.
Did I answer your question please accept this as solution.
if you liked my answer feel free to give me a Kudo 🙂
Replies (11)
Message 2 of 12
mdavis22569
It shouldn't have been an issue ..if there was anything in the file,
can you attach it?
Mike Davis
Message 3 of 12
Torben.pedersen
Yeah I know that there should't be any issues, but there was. I think the file is korrupt/broken. I´m afraid I´m not allowed to attach the file due to it´s a costumers file.
Message 4 of 12
mdavis22569
more than likely corrupt ...
With the new Anycad and the translation updates over the past few years ..it's not as common to get back files like it was back in the day.
If you're opening a native SLDPRT right into Inventor 16 and nothing comes in ...betting it's on their end
Mike Davis
Message 5 of 12
Torben.pedersen
I have the latest update to inventor 2016. I´m not sure that it´s a Solidworks part, it could be proE, NX or maybe some other that use the .prt
Message 6 of 12
-niels-
If you switch to the "select" tab on the import dialog, there should be a button to "load model".
Does anything show up on screen if you hit that?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 7 of 12
Torben.pedersen
yeah I have tried that to, nothing came up
Message 8 of 12
-niels-
Then i also think it's likely corrupt or just an empty file.
Best thing is to ask your customer to send it again and make them check on their end if it imports properly with their own software.
Niels van der Veer
The Netherlands
Message 9 of 12
Hi Mads.refgaard
If your supplier has sent the Cad model to you, can you check with them to see if
they have rolled back the Feature tree (Inventor ref End of Part)
You can do exactly the same with Solid Works to reduce file size when e-mailing data.
It might be worth a try,
Hope this helps
Cheers
Mark
Inventor 2014
Message 10 of 12
Torben.pedersen
I have told them that the file may be corrupt, and asked them to send another + a stp file format. yeah I know that trick to lower the size, prehabs thats what they have done, I will wait till the send a new file, and then aske them. I´ll keep you informed.
Message 11 of 12
Mark.Lancaster
What version of Solidworks is the file?  Inventor 2016 can only open up to Solidsworks 2015
And in Update #1 for Inventor 2016, that update resolved an issue with failing to open Solidwork 2015 SP2 files that were created in that version.  So make sure you have SP1 installed for Inventor 2016.
Mark Lancaster
Message 12 of 12
Torben.pedersen
I have no idea what version they have used, or if it is a solidworks file, it might also be from ProE or an other program, that uses .prt.
I have that opdate, and I´m aware of the problem about the opdate 🙂
I´m gonna try asking what version and program they use 🙂
