Odd Right Click Behavior
rttechno
Message 1 of 63
rttechno
I was wondering if anybody else is experiencing an issue with right click context menus?  Sometimes, not all the time, when I right click on a part in the browser the menu comes up and the item the cursor is on gets a left click as the right mouse button lifts...  I'm not sure if I have a mouse issue or an Inventor issue.  I can't make the mouse do that in any other program but it's possible that's because other software pops the menu to the side of the cursor instead of under it.  I have undocked the browser and I use it in a second screen normally.  To record the screencast I dragged it back over the main Inventor window.  I got the right then left click action a couple times and then it acted like it was clicking in the graphics window instead of the browser.  Is undocking the browser a bit buggy?  I'll attach a screencast showing the issue and I'll quickly duck into Call of Duty to see if my gun fires when I raise the scope....
Randy Martens
RT Technologies
Inventor 2018.1.1
Replies (62)
Message 61 of 63
dsDRB4K
No impact after toggling the marking menu off a few different ways. About 50% of the time, the right-click release immediately registers as a selection. The other half of the time it is unclear if there simply was no valid selection under the cursor.
It sounds like Inventor takes control of right-click handling for features like the marking menu. It's possible my setup is forcing a built in drag distance or delay timer to be way too short. There doesn't appear to be any option to remove or configure this right-click behavior.
Some More Info:
Win 11
Legion 5 15ARP8 Laptop
My monitor setup and resolution is a bit complex, monitor 3 is running some sort of upscaling that appears to affect the ui scale on occasion. This issue may have surfaced during swapping back and forth between laptop screen and multi-screen layouts.
Message 62 of 63
johnsonshiue
Hi! Please make sure the display hosting Inventor is the main display.
Many thanks!
Software Test Engineer
Message 63 of 63
rttechno
Hi Guys,
I haven't noticed this issue in 2027 yet but it might just be my clicking slowing down a bit these days.  When I originally had the issue it was tied to how quickly I pressed and released the right click button.  If I click slllloooowwwlllyyy, like cliiiiick, everything worked correctly.  If I clicked super fast (like I normally did when flying on a project) I'd see the context menu pop and whatever the cursor was over would be selected without me ever left clicking.  A fix was issued by Autodesk and the problem went away.  Just some background in case I didn't already comment here.
Randy
