Notes from parts in idw
dominiek_vanwest
Message 1 of 10
dominiek_vanwest
Is there a way to have notes from parts show up in the parts idw print? I checked for notes in property fields but didn't see it.... It would be nice
to make part notations (notes) during creation of the parts and assys and have them show up when you create your idw sheets...
Thanks in advance,
Dominiek
Replies (9)
Message 2 of 10
Hi Dominiek
You cannot necessarily add a notation to be called for in the .idw however you could always just make your note as a custom iProperty and callout the iproperty in a text annotation, or part list.
Hope this helps.
Message 3 of 10
MechMachineMan
Not sure where you were planning on storing them, or the size limit of iProperties and parameters
but it would be quite possible to just make a sub-routine that takes information from in part files and makes it into a general note on an idw sheet.
Or just use a the text annotations like the guy above said.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 10
dominiek_vanwest
You mean with iLogic?
Text annotations via custom property is not possible, as the notes has multiple lines of text. Then I thought to put it in the Comments (Summary) property, but that's not accessible in idw, or is it?
Message 5 of 10
Comments (Summary) is accessible, at least in Inventor Pro 2016 it is.
Message 6 of 10
mcgyvr
Can you give a good detailed example of what these notes are?
Message 7 of 10
dominiek_vanwest
We have 2015. So we'll have to wait till we have the next release 🙂
But we actually can't use Comments, as we use Comments in our parts list.
Message 8 of 10
dominiek_vanwest
Just some simple notes that is viewable for colleagues and clients too if necessary. But clients only get a drawing (PDF), and colleagues might only look at the part.
Message 9 of 10
mcgyvr
Not a "detailed" answer like I would have hoped and maybe had a chance to offer better suggestions..
There is "Engineering Notes" in part files and the text could simply be copied to annotation text in a drawing.
Why are you using comments already and can you change that process?
There is "design notes" app for Inventor (actually really good.. I used it when it was free but its still only $0.99) http://cadtoolbox.com/design-notes-for-inventor/
Says you can
  • View notes referenced within a drawing or assembly from child files.
I use custom iprops to fill out 8 or so notes on a drawing automatically.. Everything from finish to material to handling notes to pretreatments,etc... A simple ilogic forum creates them from a list of my standard finishes/notes,etc...
Message 10 of 10
dominiek_vanwest
Copying is an absolute NO GO (and that's not just for us, but should be for everybody). That's manual work, takes too much time and could give wrong info if you forget to copy it when you have changed the notes in the part/assembly itself.
Comments is used in our partslist to give some simple info. Changing this would mean we would need to change all our standard parts/assemblies/idws and that's just too much work.
But if the notes are accessible with iLogic, we might try something with that.
