“Not Enough Space” for Autocad Inventor 2016 Installation
Today, I installed Autodesk Inventor 2016 (Student) on a new (within the last month) Windows 8.1 computer.
The install appeared to run OK, but it missed a couple of files due to my moving and renaming of the "Public" Documents, Downloads, Music, etc. folders.
Fine, no problem. I just rename the folders to what Autocad is expecting:
/Public/Public Documents -> /Public/Documents.
Then I fully uninstall Autocad Inventor.
-- No Problems so far --
But then I try to reinstall. Checking requirements... and then:
Out of disk space
It's trying to install 14.5 MB on a 0 size, 0 space disk.
What is going on here?  It installed before (I had autocad open and running, just some default files were missing.)
I have since installed Plain AutoCad, which is working without any issues.
Any help or suggestions would be greatly appreciated!
- Kent Hagerman
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
Could you try out the suggested solution in the link below and see if that resolves your issue?
Install error: "Not enough disk space"
Let us know how it goes.
Thank you,
Jeffrey Sin
Autodesk Customer Support
No good, I'm getting exactly the same error.  😞
- Kent
bump
SBix26
Try posting in the Installation & Licensing Forum.  That's what it's for, and you're more likely to get help there.
Sam B
Inventor Professional 2016 Update 2
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
Boorda
