When I installed Inventor 2023, started to launch it by opening a part, and found that I can't find the Center and xyz planes. I've already tried to change their visibility on the setup, but it doesn't work, how can I fix this?
Right click on them in the browser to set them Visible.
If you still have trouble, then Attach the *.ipt file here.
Hi! Go to Tools -> App Options -> Display -> Origin 3D Indicator -> check both boxes. If it still does not work, try the followings.
1) Go to Windows Display settings and select the recommended resolution and scale.
2) Right-click on the Inventor desktop icon -> Properties -> Compatibility -> Change High DPI settings -> check both boxes.
3) If nothing above works, please take a look at the reply#14 in this thread.
https://forums.autodesk.com/t5/inventor-forum/dual-monitor-window-size-anomaly/td-p/9089549
Many thanks!
