We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
New Mesh Style for Rendering
Hi Guys & Gals,
Instead of modelling physical mesh I want to use a mesh render instead. Faster Basically.
I want similar to a standard Rectangular mesh within the Inventor already, Only I am after Mesh only 1" by 1"
I have tried copying and altering the rectangular render version but to no effect.
So I want to create my own version. I have generated a JPG of the mesh style, see image below.
But it is NOT see through like the standard Inventor Mesh. I notice the standard Inventor mesh has 3 images.
The mesh image, then the cutout image and then the Bump Image. All look similar. See screen shot image at the bottom.
Clearly I need to generate all 3 versions to achieve the see through effect.
So my question is this, How do I correctly alter my image to form the Cut out Image and Bump Image
to achieve the see through mesh render effect. What am I missing?
Your help much appreciated.
PS. Please explain in Layman's term 🙂
Ta Tony
dgorsman
The cut-out and bump maps function in a similar way.  Don't think of it as an image, think of it as an XY map of values, using the value of each pixel.  The value ranges between 0 (black) and 1 (white).  The bump map is a bit more obvious - 1 represents a raised surface, 0 represents a sunken surface, while a mid-level 0.5 is left as-is.  Note that this is only a visual effect, it never physically modifies the position of the surface.  And because it's a visual effect the apparent amount of change is very small compared with the object.  In other words, think ripples from rain drops not waves.
TheCADWhisperer
I see he has some new videos that I haven't watched, but find relevant videos here -
https://www.youtube.com/playlist?list=PLMhqIwDF76hL7JOL06D0Eetqcvb1oYca3
the time you spend will be well worth it.
-niels-
The Bump isn't necessary to create your mesh, only the cutout.
What @dgorsman is basically saying is, the color defines what gets cut in a cutout or raised in a bumpmap.
For cutouts, black is what gets cut.
For bumpmaps, the amount of gray defines elevation. (black being low, white high)
I've attached a cutout map for you.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
