AI 2018 (new installation of AI2018 on new SSD) refuses to drag Base Drawing onto Drawing
My drawing template was created years ago, is saved to the new SSD as a DWG, opened as such and a copy saved as a template. It is that template I am using.
If this YouTube video does not work in this Forum go to Get Video
Solved by JDMather. Go to Solution.
I get the same result with the ANSI(mm).dwg template.
I have migrated the template (which was originally created on AI2015) to 2018.
I have attached my template straight out of the templates --> metric folder.
Not sure I follow what you're trying to accomplish here.. Are you saying the "Drawing View" dialog is not appear?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Do not click, hold and drag from Base.
The mouse action does not occur till mouse-up, not on mouse down. (Permits debouncing of switch signal.)
Simply left click and release on the Base glyph.
No, Mark, I am saying that I cannot drag Base onto a drawing.
That's exactly what I do. I LMC on Base and drag to the drawing area, then release the left button.
That is EXACTLY what I wrote to NOT do.
That's why I wasn't following your workflow.. You have never been able to drag that ribbon icon.. Where did you think you could?
Mark Lancaster
@JDMather wrote:Do not click, hold and drag from Base.
Sorry JD. I have misread you again. What I saw was, "Do not click, ... [pause] ... hold and drag from Base." Then I missed the line at the bottom.😵
Funny, though. I would have sworn that I used to click and drag.
Anyway - works now. Thanks again.
