Inventor Forum
Need some help to get this sweep part into a flat laser part
13 REPLIES 13
Message 1 of 14
Charlies_3D_T
310 Views, 13 Replies
Is there someone who can help me to get this twisted sweep part into a flat dxf file so that i can get it lasered and that they can bend it again at the workshop?
hope someon knows how to do this?
https://we.tl/6gLuh1EoxI
13 REPLIES 13
Message 2 of 14
mcgyvr
in reply to: Charlies_3D_T
Zip up the part and post it directly here..
That silly link requires users to agree to terms just to be able to download the file.. Not to mention for all we know it could contain viruses,etc...
Message 3 of 14
Charlies_3D_T
in reply to: mcgyvr
Im not able to upload even a zip file here...  It's just a wetransfer link.
Message 4 of 14
Hi Charlies,
Inventor 2019 is not yet able to flatten shape like this. We are working on a solution. If you have access to Inventor Beta, you could try something there. There is an issue with the way the Sweep is created though. You should not use Twist to control the profile orientation. It would make the geometry unnecessarily complicated. What you need to do is the following.
0) Make XY plane visible.
1) Edit the Sweep feature.
2) Change Twist angle to 0.
3) Change Type to Path and Guide Surface -> pick XY plane as the Guide Surface.
You will see the sweep starts and ends at the desirable section orientation.
Many thanks!
Software Test Engineer
Message 5 of 14
kelly.young
in reply to: mcgyvr
@mcgyvr here's the part zipped up if you want to inspect.
Message 6 of 14
Thank you!
In mean while an other question.
I have some profiles missing in my frame generator section.
If you look at the EN 10219-2 library it starts at 40x but the real library that you can order from starts at 20x10
Where can i find the complete library? Because i need the small tubes.
Message 7 of 14
S_May
Message 8 of 14
Charlies_3D_T
in reply to: S_May
Thank you!!!
Now i know how i need to do it!
Message 9 of 14
S_May
Message 10 of 14
Charlies_3D_T
in reply to: S_May
Can i ask you one thing? if you get the body you do convert to sheet metal or what to get the folded model?
I'm still not able to upload anything here (i don't know why)
So a dropbox link: https://www.dropbox.com/sh/pea5jz6re88x1w4/AACO9BWwUmsVphmq7Zx_ZmNea?dl=0
Message 11 of 14
S_May
Message 12 of 14
Charlies_3D_T
in reply to: S_May
Thank you for your fast reply but even with these settings it doesn't work.
Can you tell me what i did wrong?
Message 13 of 14
S_May
@Charlies_3D_T,
they have done everything right, inventor can not handle this.
it does not work on the ends.
it works just as I have shown, sorry
Message 14 of 14
johnsonshiue
in reply to: S_May
Hi! Indeed, Inventor 2019 and earlier cannot flatten this bar. If you have access to Inventor Beta, there might be options there.
Many thanks!
Technology Administrators
