Need iLogic code to open and read word document
Hi
We always have different paint specifications from our clients.
I would like all our draftmen to place the same specification from the same doc file.
It could be easier if we could juste right click on an iLogic code and run it.
I'm looking for a code wich can goes on the drawing directory, open the word document and paste it in a simple annotation text.
Let say the file's name is PAINT SPEC.doc
MechMachineMan
Look into:
  • CreateObject("Word.Application")
  • GetObject("", "Word.Application")
  • GetObject(,"Word.Application")
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hi
I won't be able to do this by myself.
I have this part of code but it's not good.
SyntaxEditor Code Snippet
'get the text file
'expects to find text file in same folder as
'the current file
oWrdFile = ThisDoc.Path & "\" & "Paint Spec.docx"
'read the file
oRead = System.IO.File.OpenText(oWrdFile)
EntireFile = oRead.ReadToEnd()
oRead.Close()
oSheet = ThisDoc.Document.Sheets(1)
oGenNotes = oSheet.DrawingNotes.GeneralNotes
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
oGenNotes.AddFitted(oTG.CreatePoint2d(3, 18), EntireFile)
I dont get the good text.
Can someone help please?
MechMachineMan
I have not debugged this or tried it out, but it should be pretty close.
'Use late binding to access word to read through lines in a document
'MechMachineMan - March 2017
Sub Main()
Dim wdApp As Object
wdApp = CreateObject("Word.Application")
wdDoc = wdApp.Documents.Open("C:\WordFile.doc")
Call ParseLines()
Call wdDoc.Close(SaveChanges:= False)
wdApp.Quit
End Sub
Private wdDoc As Object
Public
Sub ParseLines()
Dim singleLine As Paragraph
Dim lineText As String
For Each singleLine In wdDoc.Paragraphs
lineText
= singleLine.Range.Text
MsgBox(lineText)
'// parse the text here...
Next
End Su
b
Justin K
Hi MMM
Close but not working.
It return this message "Error on Line 18 : Type 'Paragraph' non défini." (french)
Also my word document will always be in the same directory as my drawing and not at a stationnary directory.
It would be great if the code could search for my file in the drawing directory.
Maybe I ask to much but can it be possible to create the text every time at the same place with a coordonate on the drawing.
Thank you very much
Hi again MMM
I juste tryed something and it looks good.
You know the code I posted before yours, I just changed my word file for a text file and It is working.
If it could open a word document instead it will be great.
