Hi Binga,
Below are just a few examples of part-numbering schemes. I favor a very generic naming scheme that simply provides a unique name, over one that attempts to build in a lot of meaning into the part number and file names.
I hope this helps.
Curtis
Excerpted from Mastering Autodesk Inventor
If you do not have a part-numbering scheme already, take the time to implement one to
make working with your Inventor files easier. Keep in mind that the most effective numbering
schemes are often the simplest. Many an engineering department has eventually run into unanticipated
limitations when using a numbering scheme that is too specific or when attempting to
include too much information in some built-in code. Here are a few suggestions that may help
you in determining a numbering scheme that will work well for you:
Sequential Project-Based: 0910–00001
Here, the first four digits correspond to the project number and the last five are sequenced, starting at 00001. This numbering system works well when parts are not often used across different projects. Common parts might be created under a “common part project” prefix such as 7777.
Generic Date-Based: 09–0707–01
Here, the first six numbers are assigned by using the current date when the part number is created. In this example, the part number was created on July 7, 2009. The last two digits are sequenced starting with 01. This is a highly flexible numbering system that allows 100 part numbers to be created per day. If more than 100 are needed, then backdating using an unused date can be done. The date itself holds no real significance, other than helping to ensure the unique part numbers.
Sequential Product-Based: NG-00001
Here the first two letters reflect a specific product line, such as the Next Generation (NG) line, and the last five are sequenced starting at 00001. This numbering system works well when products lines are engineered and maintained separately.
Once you’ve decided on a part numbering scheme, you will want to come up with a central
part number log file or tracking system to be used in assigning numbers to ensure that there are
no duplicates. If you have a resource planning system (commonly referred to as a manufacturing
resource planning [MRP] or enterprise resource planning [ERP] system), you likely have the
ability to manage part numbers using that software. If not, a simple XLS spreadsheet fi le can be
used to assist with this task.
