Drawing View Borders - Drawing Views not updating?
ToddPig
ToddPig
All of my drawing views now have a yellow border in the corners.  I don't remember this before downgrading to 2017.
When I hover over the drawing feature tree, I can see each view is in a different completion percentage.  I have one view that has been stuck at 99% for 25 minutes.  I'm not even sure if these issues are related (found conflicting info with searching the forum)
Please see the attached image for a visual of the yellow corners (the black arrows were added)
Todd
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Curtis_Waguespack
Hi ToddPig,
I don't always see color correctly, but I think those are generally regarded as green rather then yellow. I only mention this because a search for "Autodesk Inventor Drawing View Yellow Corner" might not yield much.
If you right click the view, I think you'll be able to choose "Make View Precise".
related link:
http://blogs.rand.com/manufacturing/2016/01/tech-tips-dynamic-scaling-of-drawing-views.html
I hope this helps.
Curtis
ToddPig
Sorry, Green borders. I'm color deficient, so I asked a co-worker what color the borders were, but I guess I should've asked if he was also color deficient.
I'll search for "Green corners/borders"
The "Make Precise" option was only visible on 2 of my views, but grayed out. The "Make All Views Precise" was not grayed out, so I clicked it (on both views) both I did not notice a change.
I had the link you suggest already bookmarked, it's great.
Inventor 2018
iParts = iHeadache
michael_wardas
Make precise worked for me!
Thank you!
