Missing Files - Textures
Binga
Advisor Advisor
Message 1 of 1
Binga
Hello.
My textures files are unlinked. Look:
I changed the "Texture folder" like this post teaches: http://forums.autodesk.com/t5/inventor-general-discussion/textures-missing-2017/m-p/6361346#M598229
Then, I realized that my windos didnt redect to the folder %PUBLICDOCUMENTS%. So, I have created one "Environment Variable" and now my windows searches this path.
It is occuring both in Inventor Library as in Autodesk Appearance Library.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Replies (0)
