Move command
Move command
Move command
I don't know what it is but I can never get the "move" command to seem to do anything while in a sketch. If I want to move a group of holes in a sketch, I select the Move command, select objjects, slsect base point and then select "precise input", enter the x-y values, but nothing moves?
JDMather
@Anonymous wrote:
... If I want to move a group of holes in a sketch,
Make a Sketch Block.
Attach your *.ipt file here if you can't figure it out.
Binga
Select the entities.
Choose a base point.
Then, insert the X and Y distances (in this option)
THEN PRESS ENTER!
 @JDMather
(How can I quote your answer?)
Do you have some tutorial to do sketch blocks?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
JDMather
@Binga wrote:
@ @Anonymous
Probably - but Autodesk Screencast site is such a disaster it would take me too long to find.
Maybe someday they will figure out how to ......
Curtis_Waguespack
Hi KevinPinks7697,
It could be due to your Relax Mode settings:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-A70EA377-475A-4A54-86B4-D653ED1708D0
I notice that if any of the sketch points are constrained to a projected geometry, it doesn't work, regardless of the Relax Mode settings.
I hope this helps.
Curtis
