MULTIPLE PURCHASED PARTS WITH A SINGLE PART NUMBER
jdrann
jdrann
DOES ANYBODY KNOW A WAY TO MODEL A 2 PIECE PURCHASED PART AND HAVE IT REPORT TO A SINGLE PART NUMBER, I.E. DRAWER SLIDES, THEY MAY ALWAYS BE IN A DIFFERENT POSITION SO THEY CANT REPORT TO A SINGLE PURCHASED ASSEMBLY
Cadmanto
You can use multi bodied parts to do this.
You just can't apply different materials to each body.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
jtylerbc
One option might be to make it a Flexible assembly.  One slide of the pair could be constrained to the origin, and the other left unconstrained.  Then set the subassembly as Flexible in your main assembly, and constrain as though they actually were separate parts.  This would probably be my preferred way of modeling something like this.
Another would be to just insert the two parts separately, but have one of them set to the "Phantom" BOM structure.  The "Phantom" part would not show up in the BOM.  The one left as "Normal" BOM structure would carry the part number of the purchased assembly.
Although my usual preference for something like this would be the first method, I have used the second in situations where the two parts needed to be at different levels in the assembly.  Think of something like a toolbox, where you have:
  1. Weldment for the body of the toolbox.
  2. Weldment for the lid of the toolbox.
  3. A draw latch, with the latch body welded to the box, and the catch plate welded to the lid.
  4. Draw latch assembly is sold as a single purchased assembly.
In my case, I used the main body of the latch (which is the bigger piece) to carry the part number, and set the catch plate as Phantom.
Cadmanto
You can also create an iAssembly with the factory assembly being your main part number and then each member being the main number with a dashed extention.
Inventor Pro 2018
Best Regards,
Scott McFadden
blandb
Can you not just model the slide as an assembly that is made up of the components that make the slide. Then create positional reps in the slide such as: "master" being a closed state, then an "open" to show slide extended out. That way when you use your slide in other assemblies, it will be (1) line item such as Drawer slide PN-####.
At the parent level assy where you place the slide, you can then utilize the Positional reps of that slide to show the drawer in a default closed position, then have the alternates to show different states for drawing purposes.
Hope that helps.
Autodesk Certified Professional
