Hi!
Anybody knows if it´s posible to relocate the triad without move the part at the same time to the place I want when moving components in Inventor Studio? I´m working with the 2015 version.
I´m going crazy 😞
Fco. García Bayarri
Delineante industrial | Formador técnico
LinkedIn | YouTube | Twitter | Telegram
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta.
Please give me Kudos and mark this answer as Accept as Solution if it answers your question.
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I try that before but....
Niels van der Veer
The Netherlands
No. It´s an assembly completly free of constrains cause I know constrains and move components are not compatible.
Niels van der Veer
The Netherlands
This is the assembly in question. It was modeled with the 2015 version of a file from STP.
Thank you.
Ok, i see the problem now... but maybe you can use that to your advantage.
I did this in 2016, but i think it should work the same in 2015:
Niels van der Veer
The Netherlands
No problem, Niels.
If it doesn´t work with the 2015 version I will try it at home with my 2016 student version at home.
Thank you so much.
