Inventor Forum
Moving component in Inventor Studio
8 REPLIES 8
Message 1 of 9
Francisco_García
1398 Views, 8 Replies
Hi!
Anybody knows if it´s posible to relocate the triad without move the part at the same time to the place I want when moving components in Inventor Studio? I´m working with the 2015 version.
I´m going crazy 😞
Fco. García Bayarri
Delineante industrial | Formador técnico
LinkedIn | YouTube | Twitter | Telegram
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta.
Please give me Kudos and mark this answer as Accept as Solution if it answers your question.
Tags (3)
8 REPLIES 8
Message 2 of 9
-niels-
in reply to: Francisco_García
I think you're on the right track, but instead of hitting "ok" (the green mark) after you redefine you should just continue positioning...
(in your gif you can see the redefine button return to the clickable "color" after you select the edge, so just continue after that)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 9
Francisco_García
in reply to: -niels-
I try that before but....
Fco. García Bayarri
Message 4 of 9
-niels-
Are there constraints holding the part in place?
Niels van der Veer
The Netherlands
Message 5 of 9
Francisco_García
No. It´s an assembly completly free of constrains cause I know constrains and move components are not compatible.
Fco. García Bayarri
Message 6 of 9
-niels-
Hmm, wel i tried the workflow in 2016 and that worked.
So i don't know what might be different in your situation...
I'm not at work now, so i can't check anything.
Is it possible for you to share your assembly so others might help?
Niels van der Veer
The Netherlands
Message 7 of 9
Francisco_García
This is the assembly in question. It was modeled with the 2015 version of a file from STP.
Thank you.
Fco. García Bayarri
Message 8 of 9
-niels-
Ok, i see the problem now... but maybe you can use that to your advantage.
I did this in 2016, but i think it should work the same in 2015:
Basically you just realign your part twice and move it the distance you need in between those realignments...
BTW, kudos on the beautifull animation!
Niels van der Veer
The Netherlands
Message 9 of 9
Francisco_García
No problem, Niels.
If it doesn´t work with the 2015 version I will try it at home with my 2016 student version at home.
Thank you so much.
Fco. García Bayarri
