Movement with 1 constraint - Inventor
Johan_Degreef
Johan_Degreef
I have a groundfloor (grounded or constrained part), I place a tank on it with only 1 contrain: Mate between bottom tank, and top groundfloor.
For Meeting purposes, I want to move the tank around, which goes perfect. Is there a way to rotate the tank on it's spot too, keeping the base on the ground?
@Johan_Degreef Your post title was modified to add the product name to increase findability - CGBenner
Accepted solutions (3)
andrewiv
You could use free rotate.  That would allow you to rotate the part while ignoring existing constraints, then when you update it will re-apply the constraints and leave the part rotated.
Andrew In’t Veld
Designer / CAD Administrator
kacper.suchomski
You can also add a constraint (mate/angle) and then remove it.
Kacper Suchomski
Johan_Degreef
Nothing like: hold shift and then you can rotate in place, or select the axis and hold shift to rotate only?
kacper.suchomski
You can activate free rotation with the G shortcut.
If you set the view to top, you'll essentially get what you're trying to describe.
(view in My Videos)
Kacper Suchomski
CCarreiras
Hi!
Yes you can, use Grip Snap.... check the video below..
(view in My Videos)
CCarreiras
