Movement with 1 constraint - Inventor
Johan_Degreef
Johan_Degreef
I have a groundfloor (grounded or constrained part), I place a tank on it with only 1 contrain: Mate between bottom tank, and top groundfloor.
For Meeting purposes, I want to move the tank around, which goes perfect. Is there a way to rotate the tank on it's spot too, keeping the base on the ground?
@Johan_Degreef Your post title was modified to add the product name to increase findability - CGBenner
Accepted solutions (3)
andrewiv
You could use free rotate.  That would allow you to rotate the part while ignoring existing constraints, then when you update it will re-apply the constraints and leave the part rotated.
Andrew In’t Veld
Designer / CAD Administrator
kacper.suchomski
You can also add a constraint (mate/angle) and then remove it.
Kacper Suchomski
Johan_Degreef
Nothing like: hold shift and then you can rotate in place, or select the axis and hold shift to rotate only?
kacper.suchomski
You can activate free rotation with the G shortcut.
If you set the view to top, you'll essentially get what you're trying to describe.
Kacper Suchomski
CCarreiras
Hi!
Yes you can, use Grip Snap.... check the video below..
CCarreiras
