.ipn scene drag reorder ?
timdown73
Message 1 of 9
timdown73
Hello all,
In a .ipn presentation file is there a way to drag a scene in the browser as shown below. Obviously I want scene 2 right below scene 1.
-Tim U.
Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz 2.30 GHz>Memory: 32.0 GB Ram
Op Sys: Windows 10 professional
Replies (8)
Message 2 of 9
mcgyvr
Reordering does not scene to be possible at this time.. Smiley Wink
Message 3 of 9
timdown73
Ok, thanks! Scenes like it should be.Smiley Frustrated
-Tim U.
Message 4 of 9
mcgyvr
@timdown73 wrote:
Ok, thanks! Seems like it should be.Smiley Frustrated
Yes it certainly scenes like it should...
For some reason though they have chosen to not allow that at this time.. The presentation environment got a rushed overhaul a bit back and is just lower priority it scenes for Autodesk.. I guess due to lack of a large user base/low demand for improvement..
Message 5 of 9
timdown73
Too bad it's not getting the attention it deserves. I'm learning to use it more and more and it works really well in spite of it's shortcomings. One of which is the selection abilities. Selecting what you want to tweak and what you don't can be laborious because there's no "select all" command in the environment. Thanks though. If you're positive that the reorder can't be done, I'll select it as the solution.
-Tim U.
Message 6 of 9
Carlos_2114
We need this option! We are in 2019 and a simple move of scenes should be available by default!
It's a shame to have to post elements as basic as that ...
Message 7 of 9
cstarker6VCG4
This needs to be added. We use scenes for views in assembly instructions. Each scene usually corresponds to an instruction step. Being able to reorganize these would be invaluable.
Message 8 of 9
Mark_Collins9R775
It's now 2025 and we still can't reorder scenes?!?!
Message 9 of 9
Carlos_2114
Maybe when Inventor 2050 comes out?...
