Move component for subcategory custom library
joaopirotta
joaopirotta
I would like know how copy a component of library and move to a library custom within category existente.
For the exemplo:
I have a library custom as a category created by "Custom Library > Bolt"
Bolt is a subcategory. I would like move a component copy from direct subcategory. (Bolt) See imagem in attachent.
rui_wang
Hi Joao Pirotta,
The workflow which you described is limitation here.
If you want to have families in new (sub) category, you should publish these families by yourself.
-Rui
Huan.Yu_Autodesk
Currently when you publish Part/iPart to your custom library, you can choose your own folder/category. If you copy a family from the standard library to your own library, the category hierarchy will be maintained because there is authorizing information for the specific category while the new folder/category has no or different authoring info.
Can you please share more information about this requirement? Also, feel free to log an idea on the Idea site: https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thank you!
-Huan Yu
