How to Create a Curved Hole?
Hi everybody,
I am looking to create a curved hole.  Imagine a tunnel snaking through a solid block that changes its angle as it works its way through the material.  Is there a quick way to do this in Inventor?
You can do that with Sweep.
JDMather
If you can't figure out the Sweep - attach your *.ipt file here.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Here is a brief screencast of how to make a sweep cut.
What kind of snaking project are you getting into?
Please select the Accept as Solution button if a post solves your issue or answers your question.
