Message 1 of 10
Modeling question - Using a 3D solid as a sweep tool?
06:30 AM
Hi there.
I’m trying to model the machining detail into a cylindrical part.
Basically I need to do a sweep feature, but rather than using a 2D sketch, I need the sweep “tool” to be a 3D shape.
If you skip to 1:38 in this video: https://www.youtube.com/watch?v=o3IQv9mT6JU , that’s very similar to the type of machining I need to model for, but with the tool only going to a certain depth into a solid rod.
I'm (hopefully) attaching a screenshot/explanation, and the part.
Is there a way to do this?
Thanks in advance,
Felix
edit:
(offset, split, then thicken won't work, as the edges of the cut aren't then parallel as they would be in real life)
(standard sweep wont work, as there are no radiuses so the corners go weird)
