04:47 AM
- Mute
- Permalink
- Report
If I have problems with the result if I follow the next procedure
1. Add some model parameters in a linear diameter dimension in a drawing.
2. Export to DWG.
If I export to PDF the result is ok but to DWG then I get x#; (where # is a number) in place of the model parameter value. With normal dimensions it is also ok.
I attach a coulple pictures where it can be seen.
Am I doing something wrong? How can I solve this?
Thank you very much.
