Inventor Forum
Missing Imported Parameters
4 REPLIES 4
301 Views, 4 Replies
I can export my paramerts to XML fine however when I import them back in there are always 2 particular ones that come back in blank. They are TEXT and multi-value (2 values) but I have others that are text, multi-value with 2 values that import ok.
Has anyone had a similar issue?
4 REPLIES 4
Mark.Lancaster
gazadder
It will help us if you specify what version of Inventor you are using and what service packs/hot fixes have you applied to that Inventor version.
Also a screen shot showing the problem...
Mark Lancaster
JDMather
in reply to: Mark.Lancaster
@Mark.Lancaster wrote:
gazadder
It will help us if you ...
And better yet, relevant files that illustrate the behavior.
Sorry been on vacation.
Inventor 2014 SP2. How do you find out what hot fixes are installed?
The problem is a few parameters that are multi-list do not get inported back in correctly so the parameter has a blank value. The only way to may it un-blank is to manually select a parameter listed in its drop down.
johnsonshiue
Hi! I think there might be text-specific behavior here that I am not aware of. Could you attach an example here or send it to me directly (johnson.shiue@autodesk.com)?
Thanks!
Software Test Engineer
Technology Administrators
