Mfg. Approved By and Mfg. Approved Date don't update from Vault in Rev. Table
- Mute
- Permalink
- Report
Hello
These two fields aren't updated from Vault in the rev table when they are modified in Vault client.
Here are the steps:
- I have a drawing with a revision table with these two fields; I also create a text note with these two fields. Initially they don't have any info displayed
- I checked in the file in Vault and add values to these two fields; they show in Vault as expected.
- I check out the drawing in Inventor and automatically both fields are updated in Revision Table and Text Note.
- I check in the drawing back to Vault and modify these two fields; Vault works as expected, changes are displayed.
- I check out the drawing in Inventor and both fields in Revision Table are not showing the new changes from Vault. However, the text note is updated and shows the changes.
- I tried different settings in the Vault revision table command, Data card, Update Properties in INV, etc
- If I look into the iProperties of the drawing, the new vault changes are there... they are just not updating the revision table accordingly. I have to manually do something in the iproperties to get APPLY button active and then will trigger the revision table update.
Am I missing something or it's just a bug?
I'm using Inventor/Vault 2019 and will check it soon in 2020.
Thank you for any suggestion.
radu
