Mesh Units
Mesh Units
Mesh Units
Hello!
I wanted to ask what units are in the Mesh Settings for the static Analysis?
I want to analyse per 1mm, so I need to insert what?
Thank you!
JDMather
@Anonymous
Attach your file here for demonstration.
johnsonshiue
Hi! As the dialog indicate, it is fraction (percentage) of the bounding box. So, if the body is in mm, you can find out the bounding box by using iLogic -> Measure -< ExtentsLength, ExtentsWidth, and ExtentsHeight. Then calculate the fraction (dividing 1mm by the length for example).
Many thanks!
Software Test Engineer
aji.sugiyantoro
I use inventor 2025
Please set the Average Element Size and Minimum Element Size to 0.1. The element size should be calculated based on the longest dimension of the bounding box.
