When dimensioning using the ordinate command, can you select the the intersection of two lines?
Solved by SBix26. Go to Solution.
Yes I think you should be able to.
Sometimes if the ordinate dimensions don't follow the line I wish them to follow, I create a sketch and add a tiny line (hardly visible on the drawing) perpendicular to the line I want the ordinate dimension to follow. I exit the sketch and then create the ordinate dimensions based on that tiny line. If the intersection doesn't work for some reason you could create a point there by way of sketch, but I don't see why it wouldn't work.
In ordinate you have to trace the lines. So whilst in the dimension command you run your cursor over one line and then then over the other and trace to where the intersection would be, then it gives you the option.
Video here:
With ordinate dimensions, you should be able to place one to an intersection of two lines by simply swiping on one, then the other, and finding the point where the dotted extension lines are both lit up. However, the ability to do this while placing the dimension depends on this setting in Application Options:
With this option selected, you pick geometry (lines, arcs, etc.) and Inventor automatically adds dimensions to the key points of those geometric items. With it unchecked, you pick individual points or lines.
If you want to select intersections while placing the dimensions, you will need to leave this option unchecked. But you can always move ordinate dimensions to intersections after the fact. The great thing about dimensioning to intersections (rather than to sketch points) is that Inventor provides the extensions to the intersection point, you don't have to sketch them.
Edit: I see @SharkDesign beat me to the answer, but the video and text in the knowledge base article are not quite correct: you can drag existing dimensions to intersections (you don't have to delete/add); and if the option above is unchecked, you can do all the intersections at first placement.
Sam B
Inventor Pro 2022.1.1 | Windows 10 Home 20H2
LinkedIn
Appreciate the suggestions from everyone, I started out with Solidworks in school and the first couple of companies I worked for. This is my first time having to use Inventor so I'm trying to navigate through the differences without any help. I'll probably be visiting the forum frequently.
