Inventor Forum
macro available to strip title block?
2 REPLIES 2
333 Views, 2 Replies
i need to take inventor drawings and remove anything that references the customer, so they can be sent out to outside vendors to quote building. there is a note on the drawing that needs to be removed and in the title block the customers logo and name with address also needs to go. I am running 2011. Is there a simpler way than opening each drawing (about 200) and editing the title block, saving, and then batch plotting all ? I thought I could take the template and remove the things I didn't need, open the drawing and have it look for the revised template, but it looks like the title block info is stored the each drawing.
Anyone got any suggestions...
**** Smith
2 REPLIES 2
found my own solution... used task scheduler. converted one to atuocad. then converted that to acad 2000 (because i only one here with inventor on machine, this is a solid works group, probably 30 some seats) and made a configuration file. then back to task scheduler. export all inventor drawings using config file to acad 2000....sure impressed a few people with the power of Inventor!
Thanks.
I need to go somewhere where Inventor is used!!! Really miss it......
mcgyvr
You could have just used the "Drawing Resourse Transfer Wizard" to replace the title blocks with the new "non-company specific" one.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0684-Collabor684/0725-Tools725/0...
