Inventor Forum
INCH xyz versus MM xyz coordinate system error
3 REPLIES 3
Justin_DeSilva
725 Views, 3 Replies
Inventor LT 2012
When opening template files I've discovered a problem. INCH and MM coordinate values are not identical. Iv'e tried reconfiguring the coordinate values however they prove false when using sketch relations. For instance, sketch relation horizontal is actually applying a vertical sketch relation, and vise versa. Why is this so?
Also, after creating a mm template file whose coordinate system is similar to inch template file, the home view when opening is reveresed. When selcting the home icon located on the view cube, the orientation in mm template file is reversed and rotates 180 degrees?
3 REPLIES 3
ampster40
in reply to: Justin_DeSilva
wonder if First Angle vs Third Angle is the cause...
mcgyvr
in reply to: ampster40
I always thought people using the metric system were wrong.. This proves it Smiley Very Happy
cwhetten
I have noticed the same thing.
You just need to change the view cube orientation in your template file (it's relative anyway, so it's no big deal).  Re-orientate your view so that the Z-axis is pointing out of your screen towards you and the Y-axis is pointing up, then right-click on the view cube and select "Set Current View as > Front".
Secondly, click on the Front-Top-Right corner of the view cube to re-orientate your isometric view (make sure the Y-axis is still pointing up).  Then right-click the view cube again and choose "Set Current View as Home > (whichever option you prefer)".  Make sure to save this into your (mm) template so that you don't have to do this with every new file anymore.
-cwhetten
