i need to take inventor drawings and remove anything that references the customer, so they can be sent out to outside vendors to quote building. there is a note on the drawing that needs to be removed and in the title block the customers logo and name with address also needs to go. I am running 2011. Is there a simpler way than opening each drawing (about 200) and editing the title block, saving, and then batch plotting all ? I thought I could take the template and remove the things I didn't need, open the drawing and have it look for the revised template, but it looks like the title block info is stored the each drawing.
Anyone got any suggestions...
**** Smith
Solved by mcgyvr. Go to Solution.
found my own solution... used task scheduler. converted one to atuocad. then converted that to acad 2000 (because i only one here with inventor on machine, this is a solid works group, probably 30 some seats) and made a configuration file. then back to task scheduler. export all inventor drawings using config file to acad 2000....sure impressed a few people with the power of Inventor!
Thanks.
I need to go somewhere where Inventor is used!!! Really miss it......
You could have just used the "Drawing Resourse Transfer Wizard" to replace the title blocks with the new "non-company specific" one.
