Inventor Forum
lourve feature
8 REPLIES 8
Message 1 of 9
550 Views, 8 Replies
lourve feature
Can 5 louvres fit in the circle?
If yes how do i place the 5 lourves in the circle area?
2015 part started but i need help with the lourves
8 REPLIES 8
Message 2 of 9
I need some help proceeding to create the hood of the lourve. Can this be done?
Please see 2015 part attached
CB
Message 3 of 9
mcgyvr
louver punch tools here..
http://www.cbliss.com/inventor/iFeatures/
Message 4 of 9
JDMather
I don't have time right now to work up a solution, but as a bit of encouragement I would say yes, it can definitely be done.
You might download the old iFeature examples from cbliss.com for reference. Yeah - what mcgyvr said.
Message 5 of 9
in reply to: JDMather
How do i make a variety of sizes. Can i make a table of various sizes?
Message 6 of 9
JDMather
I think you must have misunderstood the cbliss iFeature reference - you don't use this - you only examine to see how it was done and then use that technique (from scratch) to solve your problem, essentially, answer the question you just asked.  You simply need to constrain to your sketch circle.
Message 7 of 9
mcgyvr
Simply use multiple punch features (via multiple sketches.. or share the sketch and use the required sketch points multiple times) and give each one the required size..
Notice the "size" tab of the punch tool dialog box during placement..
Note: any that are the same size could be done with 1 sketch (like the top/bottom louver)
Message 8 of 9
alanrichardson
See if these files help you with your project . . .
When you open the IPT files, roll down the 'end of part' marker to see the part history.
They should give you a good start.
Inventor 2020, Windows 10
Message 9 of 9
in reply to: alanrichardson
Thanks Alan. Appreciate the models
Technology Administrators
