Lofted Flange refold failure
Message 1 of 13
When creating cone with lofted flange feature I encounter problems in each different approach. I needed to apply unfold feature to add holes on the cone with intention refold it back to cone again. Unfortunately Inventor is giving failure comments for each different approach solving this problem
could not replace the geometry with desired contour
feature compute failed
Please help to solve this issue.
Replies (12)
Message 2 of 13
S_May
@Anonymous
2019-06-03 10_16_46-Autodesk Inventor Professional 2020.png2019-06-03 10_16_59-Autodesk Inventor Professional 2020.png
Message 3 of 13
Many thanks for quick response!
Please describe what was the issue so the next time I will not start spoiling the forum 🙂
Unfortunately I have 2019 inventor and I am not able to open the file. Please save in older version if possible.
Message 4 of 13
S_May
@Anonymous
Message 5 of 13
Unfortunately I get errors creating this model. I have Inventor 2019.
The model is created by lofted flange. I use one of the segments plane and through  cut normal I am able to create hole which is perpendicular to flat pattern surface.
But as I create hole pattern and then flat pattern inventor goes to sand watch regime and afterwords shows an error me message at the same time showing some incredible artistic capability by twisting my ipt (picture enclosed)
Messages are could not build this cut and etc...
Message 6 of 13
johnsonshiue
Hi Jaanus,
The flat pattern failure has been fixed as of 2019.4 update (see attached file). I notice you are still on 2019.3. Please install 2019.4.
Many thanks!
Software Test Engineer
Message 7 of 13
Thanks for a hint.
After some manipulations the pattern was generated, but the part is not correctly visualised*(2019.4). Pattern holes visually  do not penetrate through sheet metal. Aftercut does not help as well because as I understand it does not see any "physical material" to be cut.
Unfortunately the 3d view is spoiled and the drawing view and flat pattern as well. I imagine we would have to manually correct the idw..
Can you please help to solve this issue?
Message 8 of 13
johnsonshiue
Hi! Please attach the new part here. The hole you added was not present in the file you originally attached.
Many thanks!
Message 9 of 13
ipt file is encolsed
Message 10 of 13
RonaldVanHam8261
Hello everyone,
I just made a die formed lofted flange (cone)
I made a centred rip with a 2mm gap exactly on the intersection of the XY plane and te surface of the cone.
Then I need to unfold the lofted flange in order to add a certain hole pattern.
As the stationary reference I use the left side of the rip.
The part is unfolded as required and I've provided the pattern
After this I refold the part with ofcource the same surface of the rip as the stationary reference.
But strangely enough the position of the rip is on acompletely different position after refolding.
What am I doing wrong ??
RonaldVanHam8261_0-1764682102849.png RonaldVanHam8261_1-1764682144895.png RonaldVanHam8261_2-1764682287736.png
I Hope someone can help me with this issue.
Many thanks in advance.
Best Regards,
Ronald.
Message 11 of 13
johnsonshiue
Hi Ronald,
Please share the file here. I would like to understand the Refold failure better.
Many thanks!
Message 12 of 13
SBix26
As a side note, there is no need to use a lofted flange feature for a cone.  A simple revolve will do the job, since cones are developable features and will easily flat pattern.
That said, I don't know whether a different modeling technique would give a different result in this case.  Might be worth trying, though.
What version of Inventor are you using?
Sam B
Inventor Pro 2026.1.1 | Windows 11 Home 24H2
Message 13 of 13
heather_tracy
Hi @RonaldVanHam8261,
I wanted to check in and see if you saw @johnsonshiue's & @SBix26's follow up questions and you still needed assistance, or if you found a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
All the best,
Heather | Community Manager
