Inventor Forum
Lofted Flange refold failure
8 REPLIES 8
Message 1 of 9
454 Views, 8 Replies
When creating cone with lofted flange feature I encounter problems in each different approach. I needed to apply unfold feature to add holes on the cone with intention refold it back to cone again. Unfortunately Inventor is giving failure comments for each different approach solving this problem
could not replace the geometry with desired contour
feature compute failed
Please help to solve this issue.
8 REPLIES 8
Message 2 of 9
S_May
S_May
@Anonymous
2019-06-03 10_16_46-Autodesk Inventor Professional 2020.png2019-06-03 10_16_59-Autodesk Inventor Professional 2020.png
@Anonymous
Message 3 of 9
in reply to: S_May
Many thanks for quick response!
Please describe what was the issue so the next time I will not start spoiling the forum 🙂
Unfortunately I have 2019 inventor and I am not able to open the file. Please save in older version if possible.
Message 4 of 9
S_May
S_May
@Anonymous
@Anonymous
Message 5 of 9
in reply to: S_May
Unfortunately I get errors creating this model. I have Inventor 2019.
The model is created by lofted flange. I use one of the segments plane and through  cut normal I am able to create hole which is perpendicular to flat pattern surface.
But as I create hole pattern and then flat pattern inventor goes to sand watch regime and afterwords shows an error me message at the same time showing some incredible artistic capability by twisting my ipt (picture enclosed)
Messages are could not build this cut and etc...
Message 6 of 9
johnsonshiue
johnsonshiue
Hi Jaanus,
The flat pattern failure has been fixed as of 2019.4 update (see attached file). I notice you are still on 2019.3. Please install 2019.4.
Many thanks!
Software Test Engineer
Hi Jaanus,
Many thanks!
Message 7 of 9
in reply to: johnsonshiue
Thanks for a hint.
After some manipulations the pattern was generated, but the part is not correctly visualised*(2019.4). Pattern holes visually  do not penetrate through sheet metal. Aftercut does not help as well because as I understand it does not see any "physical material" to be cut.
Unfortunately the 3d view is spoiled and the drawing view and flat pattern as well. I imagine we would have to manually correct the idw..
Can you please help to solve this issue?
Thanks for a hint.
Message 8 of 9
johnsonshiue
johnsonshiue
Hi! Please attach the new part here. The hole you added was not present in the file you originally attached.
Many thanks!
Many thanks!
Message 9 of 9
ipt file is encolsed
