Locking Windows pauses Inventor processing
-ianf-
-ianf-
Is it a setting on my machine? But when I lock my windows laptop Inventor seems to stop it's processing.  Ideally when I leave my laptop and lock the screen (ctrl, alt & delete <lock>) to go make a drink etc,  I want Inventor to continue it's processing, like opening or saving a model.  It appears that this isn't the case.  I'm sure when I lock the screen then nothing happens at all.
Ian Farmery
Inventor & Vault 2023
Dell 7550 Xeon E-2276M, 2.80Ghz 64GB RAM
Nvidia Quadro RTX 4000, Windows 11
johnsonshiue
Hi Ian,
I don't think there is a setting in an application can dictate such behavior. There are multiple suggestions based on my limited understanding. Here is a the most plausible solution. You will need to edit a Windows registry key to enable a hidden option. Then change the sleep timeout. After that, the background process will run even after the machine is locked.
https://superuser.com/questions/1019043/windows-10-sleeps-before-set-time/1023836#1023836
Many thanks!
Software Test Engineer
-ianf-
Thanks for the reply. I'll give that a try.
Ian Farmery
