Inventor Forum
Linking dimensions
8 REPLIES 8
Message 1 of 9
bsubotic
608 Views, 8 Replies
Linking dimensions
I have iAssembly with 10 instances; the assembly consist of 1 part file and 2 ipart files. Difference of each of the iparts is the length of the instances. I have a drawing with table that correlates two iparts to each other. I want to add reference dimensions for both of the iparts and have them in the drawing table so that we can verify if production has match those 2 iparts as per drawing. I have tried adding dimension in iassembly and linking it to dimension in ipart but it does not work the way i was hoping.
Any help would be appreciated.
Thank you
8 REPLIES 8
Message 2 of 9
johnsonshiue
in reply to: bsubotic
Hi! Try this and see if it works for you. You can go to the iPart/iAssembly factory and go to Parameters table. Check "Export" flags for those driven dimensions. These dimensions will become custom iProperties. You can include them in a PartsList. The tricky thing is how these properties propagate from factory to member files. It may not be as straight forward as it seems.
Please share an example here so forum experts can take a look and comment further.
Many thanks!
Software Test Engineer
Message 3 of 9
bsubotic
in reply to: johnsonshiue
Hi johnsonshiue, i have tried your suggestion but it didn't work i am attaching example.
thank you
Message 4 of 9
johnsonshiue
Hi! I am not 100% sure about your requirements. But, based on my understanding it is doable. Please take a look at attached drawing. Is this what you were looking for?
Many thanks!
Message 5 of 9
bsubotic
Yes that is what i want i was able to add new property (DIM_A & DIM_B) for the part list but i have no clue how did you get it to show up in Part1 table and Part2 table?
thank you
Message 6 of 9
johnsonshiue
Hi! You are looking for Configuration table (Part1 and Part2 Tables). You need to use General Table command and select an iPart or iAssembly factory.
Many thanks!
Message 7 of 9
bsubotic
Sorry to bother you but i can't select an iPart or iAssembly factory it is grayed out!?
Message 8 of 9
johnsonshiue
Hi! You probably don't want to select the view. The view is based on a member, I assume. You should simply select the factory file. It should work.
Many thanks!
Message 9 of 9
bsubotic
Got it working, thank you!
Technology Administrators
