Hi Johnson,
So again, I am not looking to make it available in drawing sketch environment.
It is already available there as I explained.
I am simply looking for a way to move one UI item from one ribbon tab to another.
I can easily add any command on to any ribbon using UI customization under RMB context menu.
But when it comes to drop down UI elements, like for instance layer drop down, this does not work, even thought it should.
As shown in previous post it is possible to place "layer" on the ribbon and this should result in having a drop down, that actually almost works (if we are happy with having a drop down under an arrow icon instead of a standard familiar looking drop down lost box, and the fact that it needs to be clicked twice to actually displayed populated list instead of blank list).
This is a vary simple and basic question.
How to add a UI object (drop down) to a ribbon?
For YEARS Autodesk is advertising "Fully customizable UI" so pleas show me how.
I cam easily do that in Autocad from many years back. So I refuse to accept that Inventor, much more expensive program, does not have this simple functionality.
If not possible with build in UI customization menu, can someone show how to do that with plugin, Just for the sake of proving this can be done and Autodesk should have made it from the start.
Cris.
Cris.
Cris,
https://simply.engineering
