Issue with changing the diameter of a hole using inventor
dodoguardi
Message 1 of 8
dodoguardi
Hi Everyone,
I am relatively new to Autodesk products and I'm currently taking one of the inventor courses to learn more. In one module of the course I am required to change the hole diameter of a part. Unfortunately, I have encountered an issue with this step. When changing the diameter using the direct edit option I am prompted with a message stating "Dependent modeling failed. Try editing or delete feature." I have attached an image of this error message below.
How can I fix this error and change the diameter of the hole?
Here is the link to the course module for background: https://www.autodesk.com/certification/learn/course/inventor-3d-modeling-mechanical-design-professio...
Replies (7)
Message 2 of 8
Alexander_Chernikov
Hi,  It would be easier to find the error if you attached the part file itself.
Also indicate the version of the program and installed updates.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 3 of 8
WHolzwarth
Here's the file. I could edit it with Inventor 2023.2 without problems.
Walter Holzwarth
Message 4 of 8
BDCollett
It looks like you may be using the wrong operation with direct edit to change the diameter.
Message 5 of 8
JDMather
Message 6 of 8
Alexander_Chernikov
Hi, in the added screenshot there is letter "D" - as a diameter changing.
The problem may be due to the lack of installed updates - for version 2021 it should be 2021.4.4
Facebook | LinkedIn
Message 7 of 8
dodoguardi
Hi Alexander! Here is the part file as well as the screengrab of the Autodesk inventor version I am using. I checked for updates but none were found. Not sure where to go from here.
Message 8 of 8
Alexander_Chernikov
Hi, for the version 2023 should be ServicePack 2 - you can find it at
https://manage.autodesk.com/products/updates
or
https://manage.autodesk.com/products/INVPROSA?version=2023&platform=WIN64&language=EINT
Facebook | LinkedIn
