How do I add an angle to this flat surface?
ashton2AV59
ashton2AV59
How would I add an angle to a sketch I extruded?
Example below
The red line is the curve I'd like to add.
Everything above the red line would be cut out because of the angle.
  • Help
BDCollett
Draw a new sketch on the profile from this side, draw a shape that cuts that angle and extrude.
JDMather
@ashton2AV59
Can you Attach your *.ipt file here?
WHolzwarth
You can split it off easily by using Split - Solid section On and clicking the red line as Tool.
After that 3 options appear for keeping both parts, or selecting one or the other for removal.
Walter Holzwarth
