Isometric Dimensions on Drawing
ToddPig
ToddPig
I am trying to add dimensions to an isometric view on a drawing.  I have attached an image of what this looks like in Solidworks, and would like to make something similar in Inventor.
I have figured out lots of way to make it look bad, but haven't found the one that looks good.
FYI, Solidworks looks good the first time.
Isometric Dimensions - InventorIsometric Dimensions - InventorIsometric Dimensions - SolidworksIsometric Dimensions - Solidworks
kelly.young has embedded your images for clarity.
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Cadmanto
Ahhh, Solidworks.  12 years and a CSWP.
Dimensioning Isometric views can be challenging.  What I would suggest is on the dimensions you want to look like SW, select "Edit Dimension Styles"  And go where I show below.
This will put the dimensions inline and make it look more like the SW dimensions.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
ToddPig
This doesn't seem to help.
I even increase the font size, but if I keep increasing it, the vertical dimension will look bad.
kelly.young has embedded your image for clarity.
Inventor 2018
iParts = iHeadache
Cadmanto
Truthfully, this is one of the areas that needs to be worked on.  Dimensioning isometric views as you are seeing is challenging at best.
https://forums.autodesk.com/t5/inventor-forum/inventor-2017-isometric-drawing-dimension-text-not-ali...
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
https://forums.autodesk.com/t5/inventor-ideas/isometric-view-dimensioning-idw-file/idi-p/7048094
Inventor Pro 2018
Best Regards,
Scott McFadden
Curtis_Waguespack
Hi @ToddPig,
It should be pretty straight forward for simple parts as shown in your image, I typically just select the lines to dimension, but end point work too.
Note that if the view or your part is "off plane" or "off origin" the results can be off.  Sometimes using the right click options to select plane placement can help with that. I'd guess that something like that is what's going on, but it's just a guess.
Note too that in this video I tap the Space bar to change the dimension plane when there are multiple solutions.
I hope this helps.
Curtis
TheCADWhisperer
I have always found it to be easier to dimension isometric views in Inventor than in SolidWorks?
ToddPig
Curtis,
As always, thanks!!
Inventor 2018
iParts = iHeadache
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
