Inventor Forum
Isometric Dimensions on Drawing
6 REPLIES 6
ToddPig
4238 Views, 6 Replies
I am trying to add dimensions to an isometric view on a drawing.  I have attached an image of what this looks like in Solidworks, and would like to make something similar in Inventor.
I have figured out lots of way to make it look bad, but haven't found the one that looks good.
FYI, Solidworks looks good the first time.
Isometric Dimensions - InventorIsometric Dimensions - InventorIsometric Dimensions - SolidworksIsometric Dimensions - Solidworks
kelly.young has embedded your images for clarity.
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
6 REPLIES 6
Cadmanto
in reply to: ToddPig
Ahhh, Solidworks.  12 years and a CSWP.
Dimensioning Isometric views can be challenging.  What I would suggest is on the dimensions you want to look like SW, select "Edit Dimension Styles"  And go where I show below.
This will put the dimensions inline and make it look more like the SW dimensions.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
ToddPig
in reply to: Cadmanto
This doesn't seem to help.
I even increase the font size, but if I keep increasing it, the vertical dimension will look bad.
kelly.young has embedded your image for clarity.
Inventor 2018
iParts = iHeadache
Cadmanto
Truthfully, this is one of the areas that needs to be worked on.  Dimensioning isometric views as you are seeing is challenging at best.
https://forums.autodesk.com/t5/inventor-forum/inventor-2017-isometric-drawing-dimension-text-not-ali...
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
https://forums.autodesk.com/t5/inventor-ideas/isometric-view-dimensioning-idw-file/idi-p/7048094
Inventor Pro 2018
Best Regards,
Scott McFadden
Curtis_Waguespack
Hi @ToddPig,
It should be pretty straight forward for simple parts as shown in your image, I typically just select the lines to dimension, but end point work too.
Note that if the view or your part is "off plane" or "off origin" the results can be off.  Sometimes using the right click options to select plane placement can help with that. I'd guess that something like that is what's going on, but it's just a guess.
Note too that in this video I tap the Space bar to change the dimension plane when there are multiple solutions.
I hope this helps.
Curtis
TheCADWhisperer
I have always found it to be easier to dimension isometric views in Inventor than in SolidWorks?
ToddPig
in reply to: Curtis_Waguespack
Curtis,
As always, thanks!!
Inventor 2018
iParts = iHeadache
