Some ISO GPS symbols do not appear correctly, they are replaced by a rectangle (see image).
Re-install Inventor 2024, the problem is still presen.
Where is the problem ?
Solved by SBix26. Go to Solution.
Those symbols are contained in the font AIGDT. You could try re-installing that font, but it seems very unlikely that a .ttf file would be corrupted. Nevertheless, I have attached it here (zipped)-- simply copy it to your C:\Windows\Fonts\ folder.
Are you seeing the rectangles only in the dimension edit dialog? Which symbol did you choose in the image you posted that resulted in a rectangle? Can you post a sample drawing file with such a text problem?
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
