Inventor Forum
ISO GPS Symbol like GX
2 REPLIES 2
jakefre
199 Views, 2 Replies
Some ISO GPS symbols do not appear correctly, they are replaced by a rectangle (see image).
Re-install Inventor 2024, the problem is still presen.
Where is the problem ?
2 REPLIES 2
SBix26
in reply to: jakefre
Those symbols are contained in the font AIGDT.  You could try re-installing that font, but it seems very unlikely that a .ttf file would be corrupted.  Nevertheless, I have attached it here (zipped)-- simply copy it to your C:\Windows\Fonts\ folder.
Are you seeing the rectangles only in the dimension edit dialog?  Which symbol did you choose in the image you posted that resulted in a rectangle?  Can you post a sample drawing file with such a text problem?
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
jakefre
Re-install the font, all is ok
Technology Administrators
