Is there a way to add a calculator into a form
chris
Advisor Advisor
chris
I know you can add dim's together and parameters, but it would be nice to be able to add a simple calculator to a form, so you can do some math without having to download a program to keep the Microsoft calculator on top.
talha.tufan523TD
I knew one day someone other than me would need this. I'm currently working on it, not clear yet, but if you can reach out, I can help guide you. I'm developing an API in C#. What you see below is nothing more than a dockable window. If you have any questions, you can contact me through the provided link. I would be glad if we could develop it together. In addition, this is not just a calculator; I am also adding some functions such as managing user forms, renaming files, file explorer integration, chromium integration, pushing parameters, and changing all iProperties. I'm sure it will be great once I find the time to finish it; I just need a little motivation.😅Regards.
talha.tufan523TD
I also wanted to add a video as an example, for reference.
