Inventor Forum
Feature repetition with auto resize along curved path
3 REPLIES 3
s219405621
282 Views, 3 Replies
I would like to repeat a feature along a curved path and ensure that the given feature would auto resize based on the curved path.
Please see attached the screenshot with a mark up of what I need!
Any help would be appreciated!
3 REPLIES 3
EdvinTailwind
in reply to: s219405621
It looks like a  non-circular bottle shape, for which I would use Loft feature. If you explain or show (with images) what the final outcome is supposed to be, it will be easier to give advise.
More about Loft:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-E1E2C90E-B74D-4774-8CE1-5413CD1BE281
Hi
If the sections are circular, the Revolve tool is sufficient.
Create a longitudinal section, change the center line type to axis, and create a surface or solid as needed.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
johnsonshiue
Hi! Or, use Guide Rail Sweep. All you need is a straight path at the center. Then sweep along the path and select the spline as the guide rail.
Many thanks!
Software Test Engineer
