Is there a way to add a calculator into a form
chris
Advisor Advisor
Message 1 of 9
chris
I know you can add dim's together and parameters, but it would be nice to be able to add a simple calculator to a form, so you can do some math without having to download a program to keep the Microsoft calculator on top.
Replies (8)
Message 3 of 9
talha.tufan523TD
I knew one day someone other than me would need this. I'm currently working on it, not clear yet, but if you can reach out, I can help guide you. I'm developing an API in C#. What you see below is nothing more than a dockable window. If you have any questions, you can contact me through the provided link. I would be glad if we could develop it together. In addition, this is not just a calculator; I am also adding some functions such as managing user forms, renaming files, file explorer integration, chromium integration, pushing parameters, and changing all iProperties. I'm sure it will be great once I find the time to finish it; I just need a little motivation.😅Regards.
Message 4 of 9
talha.tufan523TD
I also wanted to add a video as an example, for reference.
(view in My Videos)
Message 5 of 9
lizaarries
Community Visitor
Community Visitor
Yes, you can add a calculator inside a form using simple JavaScript or by embedding a small calculation script that updates fields automatically when users enter values. This is useful for things like pricing or value estimates. For example, tools like https://goldcalculatorr.com/ show how weight, purity, and market price can be calculated instantly, which is a similar concept many forms use.
Message 6 of 9
SMillsYS3X2
A lot of people use multiple monitors with CAD programs for such things. Not just a calculator, but any thing you need to research on one screen while keeping your main screen on your CAD program. Or you can also use Window Key + tab to switch between different windows easily.
Message 7 of 9
adamfolukes
Community Visitor
Community Visitor
Yes, many form builders support calculators through built-in calculation fields, formulas, or custom scripts. You can automatically total prices, estimate costs, calculate percentages, or perform other math based on user input. If your platform lacks this feature, embedding a JavaScript calculator or using third-party integrations is often an effective solution.
Message 8 of 9
oliverliam56h
New Member
New Member
Hy Guys,
If the form needs to perform calculations, you can either use JavaScript directly or embed an existing calculator with an iframe or custom code. I’ve found it useful to reference ready-made tools instead of building everything from scratch. For anyone looking, offers unicalculator  across academics, finance, health, conversions, and more that can fit different form-related needs naturally.
Message 9 of 9
adamfolukes
Community Visitor
Community Visitor
Sí, puedes agregar una calculadora dentro de un formulario mediante scripts, campos calculados o complementos especializados. Esto facilita cálculos automáticos y mejora la experiencia del usuario. Si además necesitas estimar conceptos laborales como compensación por despido, Calculadora de Finiquito ofrece recursos útiles para comprender estos cálculos y completar formularios con mayor precisión y confianza.
