Inventor Forum
Is it possible to make V groove in sheet metal using flange command?
8 REPLIES 8
Message 1 of 9
2084 Views, 8 Replies
We have this cladding that 10mm thick. Using standard bend will result big radius, so we use v groove to minimize. How can we make this v groove using standard sheet metal commands like flange, etc... Please see the image below. Thank you.V GROOVE.JPG
8 REPLIES 8
Message 2 of 9
mcgyvr
You cannot accomplish that utilizing just the flange commands..
You can extrude that shape later but often times you will run into problems with the flat pattern command and getting accurate flat pattern dimensions.. So you have to decide whats important to you and what you can live with..
Quite a few have proposed workarounds from modeling the part in the as grooved material thickness to modeling it full material thickness and modifying the bend tables to get close to just including a note on the drawing about the grooving and not modeling anything to manually adding the vgroove to the flat pattern to more and more..
In general Autodesk Inventor does not really have a proven/reliable process for this somewhat uncommon practice.
A google search for "Autodesk Inventor V-grooving" will yield a bunch of posts/topics about it..
Message 3 of 9
johnsonshiue
Hi! I have seen similar requests before. Inventor does not support such groove using sheet metal workflows. The bend zone needs to have consistent thickness. One thing you can try is this. You can model the sheet metal part at 10mm thickness without the V-groove. Then derive the part as another sheet metal part. Create the V-groove using Extrusion Cut. For flat pattern, go back to the original part and make the flat pattern. And, cut the V-groove in flat pattern accodingly.
Many thanks!
Software Test Engineer
Message 4 of 9
IgorMir
With a bit of a planning it is not a problem at all. Here is how. Please see attached file. IV2020 format.
Cheers,
Igor.
Web: www.meqc.com.au
Message 5 of 9
@IgorMir, can this be done without extruding the groove through the flat pattern?
Message 6 of 9
IgorMir
Hi Randall,
It wouldn't make sense, I afraid.
You will get a Flat Pattern, based on the thickness of the material. And if the material is 16mm Thk. - the outer radius of the bend (minimal one) will be 16.01, for example. And the overall size of the flat material won't be what's needed.
That's why you have to work out what the minimal outside radius you want to get first. And that, in turn - will control the minimal thickness of the sheet metal. I hope - it is understood.
Cheers,
Igor.
Message 7 of 9
johnsonshiue
Hi Folks,
I believe Model States may help this particular case without having to create two parts. You can create two Model States. One has the cladding but one does not have it (suppressed). In the Flat Pattern, create the cladding in the reverse order.
Many thanks!
Message 8 of 9
IgorMir
in reply to: johnsonshiue
Hi Johnson,
What two parts are you talking about? All the OP wanted was to get a smallest outside radiuses on a folded thick part.
It is fairly straight forward modeling, as far as I am concerned. And I had offered a sample part to the OP.
Cheers,
Igor.
@johnsonshiue wrote:
Hi Folks,
Many thanks!
Message 9 of 9
officeCTLBL
in reply to: IgorMir
fckng genius mate, thanks
