toggle export parameter automatic
hEINSTEIN
hEINSTEIN
I use parameters to populate my bom info, Is it possible to set my part template to have the export parameter toggled for new dimensions (model parameters)?
I usually ad a sketch with 3 dimensions and write those parameters to a custom property that shows the part dimensions in the BOM.
When the part is created there are no model parameters, when the sketches are created with the 3 dimensions I use for the part description, it creates the parameters (d14;d15;d16). I would like these parameters to be exported automatically.  Is this possible?
Roddo_Tran
I am not sure if this is what you are looking for. In the part template create 3 user parameters,  length width and thickness ( or whatever name that suit you), and make sure that these parameters are exported.
When you create a part file from this templates, link your sketch dimensions to these user parameters and they will be available in the BOM of the assembly file.
James_Willo
You should be able to do with with iLogic. There is an API command to mark as 'for export,' so you could add a rule to the parameter change event trigger so that every time a new parameter is added, it gets marked.
I'm not good enough with iLogic to write that for you though.
James W
Inventor UX Designer
