Hi everyone, is it normal that in the iAssembly management table i can't switch parts from content center? usually if i use an iparts there is a option for switching between different member from the ipart family, in the case below this possibility is not available, is it a normal thing?
Solved by A.Acheson. Go to Solution.
Solved by andrewiv. Go to Solution.
I've never actually tried that, but you might have to put the different content center parts in the assembly and then suppress/unsuppress the one you want for each config.
Andrew In’t Veld
Designer
Yes unfortunately as @andrewiv suggests CC parts work in a different way than iparts You will need to suppress parts to create an iassembly. The alternative is to use an ilogic assembly and to delete the unused members and add the required members.
