Is it possible to export parts in an assembly, .iam file as .dxf files?
Message 1 of 17
my very first post here in the community.
I just learned how to export face as and export sketch as... in my case I will be exporting as .dxf files. I've utilized all the parts to build a cabinet using assembly feature in Inventor and is there any function for me to export all the parts in the assembly platform to individual .dxf files so I can view all the parts in CAM software(Enroute)?
Replies (16)
Message 2 of 17
mcgyvr
Welcome to the community!!!!
No "batch" tool that I know of for that.. There is an addin that can export dxf files of sheet metal parts and their associated flat pattern but short of that I don't know how Inventor would know the desired face to export without you manually telling it each one..
Message 3 of 17
johnsonshiue
Hi! Can Enroute CAM read other formats like STEP or SAT or DWG?
Many thanks!
Software Test Engineer
Message 4 of 17
Curtis_Waguespack
Hi kyuTACWB,
This could be done with some automation, you can search and ask programming questions of this type on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Message 5 of 17
Thank you so much for your reply!! you are officially my mentor in this
community lol.
Then is there way to lay out all the parts on a plane after you assemble?
Like a broken down cardboard box.I work in the cabinetry manufacturing
industry and we mostly do custom size cabinets so I am trying to save time
as much as possible on my end..
Message 6 of 17
Hello johnsonshiue,
I don't know about STEP or SAT but I do know for sure that Enroute imports
DWG files
Thank you for your reply!
Message 7 of 17
Hello Curtis,
Thank you so much for your advise. I will check out the customization forum
right now.
Message 8 of 17
mickmac06
Hi kyuTACWB,
I know I'm a bit late to the party, but I have a solution to your question about being able to generate DXF's for individual parts of an assembly for direct import to a CNC machine.
While Inventor does not have the ability to do this, there is an add on piece of software for Inventor called 'Woodwork for Inventor' that, once installed, will display a 'Woodwork Design' tab on your Inventor ribbon, and one of the tools included on this tab is called 'Auto Plot' which will allow you automatically generate individual DXF's for all parts of an assembly, complete with hole tables. It is also worth noting that the Woodwork for Inventor software will allow you to automatically generate a true cutting list.
Needless to say, the Woodwork for Inventor add on software comes at a price, but if you are involved in the woodworking industry and you frequently need to generate individual part DXF's for export, then it is something worth considering.
Take a look at the link below if this sounds like something that would be useful to you.
http://www.woodworkforinventor.com/
All the best,
Mike
Message 9 of 17
It is never too late to the party and thank you so very much for your reply.
As matter of fact, I checked out the woodworkforinventor.com prior to your reply since I've done some research from the day that I posted my question to this Forum and I really do think who developed woodworkforinventor and the extension to inventor made for wood working industry should be awarded for what they have created! Even by visiting the website just help me tremendously to utilize more of my inventor for my production. Unfortunately I have not contacted them for any sort of quote or pricing for the extension just yet. If you are working for woodworkforinventor.com would you please contact me via private message for more information about the add on?
Thank you for your reply once again.
With all my best,
Phillip Lee
kelly.young has redacted your email address for privacy
Message 10 of 17
MechMachineMan
@Anonymous some examples of threads I've found on the workflow:
https://forums.autodesk.com/t5/inventor-customization/export-flatpattern-to-dxf-from-assembly-filena...
https://forums.autodesk.com/t5/inventor-engineer-to-order/export-dxf-files/td-p/6904367
and so on..
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 11 of 17
mcgyvr
As matter of fact, I checked out the woodworkforinventor.com prior to your reply since I've done some research from the day that I posted my question to this Forum and I really do think who developed woodworkforinventor and the extension to inventor made for wood working industry should be awarded for what they have created! Even by visiting the website just help me tremendously to utilize more of my inventor for my production. Unfortunately I have not contacted them for any sort of quote or pricing for the extension just yet. If you are working for woodworkforinventor.com would you please contact me via my email for more information about the add on? My email is $$$$$
With all my best,
Phillip Lee
@Anonymous Phillip.. I highly suggest you contact them if you are interested.. Thats how it should work.... and I wouldn't share my email on a public forum as thats just asking for spammers to grab it and get you...
Message 12 of 17
thank you for your recommendation and warning. I will keep that in mind and
will delete my reply
Message 13 of 17
mickmac06
Hi Phillip,
Thanks for the kudos.
I don't work for Woodwork for Inventor, I'm a draughtsman, cabinet maker and furniture designer working in Nottingham, England.
The software developers that wrote the Woodwork for Inventor add on are called Celi APS and I believe they are based in Lithuania. Celi APS are an authorised Autodesk developer, so my advice for getting a quote for the WW4I software is to contact your Autodesk reseller. There is a 'Find a Reseller' tab on the website where you just enter your country and it will list the Autodesk resellers that can offer WW4I. If you are in England, then Graitec can offer this software and training.
Unlike Autodesk software, the WW4I software has not moved to the subscription only model yet, and they still offer perpetual licenses, with a yearly subscription for upgrades and technical support. The quote I received from Graitec back in May was £995 per license with an annual maintenance subscription of £225. Note that the annual WW4I subscription entitles you to install the software on multiple pcs, so you can install it on your home pc as well as the office pc.
My experience is the WW4I install is straightforward and it bolts seamlessly into your Inventor ribbon.
Now, Woodwork for Inventor is not perfect, no software is, but it goes a long way to making Inventor more user friendly for the woodworkers of the world, and Celi APS are making improvements to the software with every release.
Hope this helps,
Mike
Message 14 of 17
m.gildehaus
I'am using Publish Tool Lite.
It works fine with assemblies to get all DXFs from all parts that are build in there.
https://apps.autodesk.com/INVNTOR/de/Detail/Index?id=9179175956847245174&appLang=en&os=Win32_64
And it's free.
Message 15 of 17
Thank you so much for your reply. I will most definitely check out the code in your links.
Message 16 of 17
Thank you so very much for your hands-on experience with WW4I. I will definitely look into it via Autodesk reseller in my area.
Message 17 of 17
Thank you for the link. I will try the Publish Tool Lite to see if it shortens my workflow.
