Inventor 2016 Installation Failure
Hi guys,
I tried to install Inventor 2016 after I fixed my crushed system. (I just deleted the original system and installed a new operation system)
However, when I tried to downloaded, all my downloads failed. It showed "some installations failed", but it's actually all my installation failed.
And here is the log file.
2016/11/29:16:25:29 Solom SOLOMON-GAO === Setup started on SOLOMON-GAO by Solom ===
2016/11/29:16:25:29 Solom SOLOMON-GAO Path_Length: 154
2016/11/29:16:25:29 Solom SOLOMON-GAO Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/11/29:16:25:29 Solom SOLOMON-GAO Launch
2016/11/29:16:25:29 Solom SOLOMON-GAO CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2016/11/29:16:25:29 Solom SOLOMON-GAO Current Directory C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp
2016/11/29:16:26:43 Solom SOLOMON-GAO === Setup ended ===
2016/11/29:16:26:00 Solom SOLOMON-GAO Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/11/29:16:26:00 Solom SOLOMON-GAO Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/11/29:16:26:01 Solom SOLOMON-GAO Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/11/29:16:26:42 Solom SOLOMON-GAO Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/11/29:16:26:43 Solom SOLOMON-GAO PageOpen LaunchDialog
2016/11/29:16:26:55 Solom SOLOMON-GAO Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\Setup\AcadeUI.dll
2016/11/29:16:26:55 Solom SOLOMON-GAO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/11/29:16:27:02 Solom SOLOMON-GAO PageOpen LicenseDialog
2016/11/29:16:27:02 Solom SOLOMON-GAO PageOpen ProductInfoDialog
2016/11/29:16:27:02 Solom SOLOMON-GAO PageOpen InventorFlavorSelectionDialog
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==DefaultLanguage: en-us
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==InstallName: INVENTOR
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==ProductName: Autodesk Inventor 2016
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==DeploymentName:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==SetupTitle: Autodesk Inventor 2016
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==ConfigTransform:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==ExeParams:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==SupportLink:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==InfotainmentLink:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==MsiFileName: inventor.msi
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==AdminImageConfigName: Imgx64
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==AdminImageRoot:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==GetBaseDeploymentName:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==DeploymentLocation:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==InstallDeploymentShortcut:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==ModifyDeploymentShortcut:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==SetupLockType: 2
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==SetupNetworkType: 1
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==SystemLocale: 2052
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==EvalMsiFilePath: C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\SetupRes\eval.msi
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==InstallLogPath: C:\Users\Solom\AppData\Local\Temp\Inventor2016Install.log
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==ConfigFile: C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\Setup.ini
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==SetupPath: C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==NetworkLogPath:
2016/11/29:16:27:02 Solom SOLOMON-GAO Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/11/29:16:27:07 Solom SOLOMON-GAO Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/11/29:16:27:07 Solom SOLOMON-GAO PageOpen ProductSelectionDialog2
2016/11/29:16:28:06 Solom SOLOMON-GAO PageOpen FullProgressDialog
2016/11/29:16:28:06 Solom SOLOMON-GAO Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/11/29:16:28:07 Solom SOLOMON-GAO Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/11/29:16:28:07 Solom SOLOMON-GAO Download Play VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:09 Solom SOLOMON-GAO Download Complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:09 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/11/29:16:28:13 Solom SOLOMON-GAO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2016/11/29:16:28:14 Solom SOLOMON-GAO Download Play VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:17 Solom SOLOMON-GAO Download Complete VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:17 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2016/11/29:16:28:21 Solom SOLOMON-GAO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2016/11/29:16:28:21 Solom SOLOMON-GAO Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:24 Solom SOLOMON-GAO Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:24 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Solom\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/11/29:16:28:24 Solom SOLOMON-GAO Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/11/29:16:28:25 Solom SOLOMON-GAO Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:27 Solom SOLOMON-GAO Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:28:27 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Solom\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/11/29:16:28:27 Solom SOLOMON-GAO Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/11/29:16:28:28 Solom SOLOMON-GAO Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/11/29:16:28:42 Solom SOLOMON-GAO Download Complete CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2016/11/29:16:28:42 Solom SOLOMON-GAO Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:28:49 Solom SOLOMON-GAO Install Autodesk® Material Library 2016 Succeeded
2016/11/29:16:28:50 Solom SOLOMON-GAO Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILB...
2016/11/29:16:29:10 Solom SOLOMON-GAO Download Complete CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILB...
2016/11/29:16:29:10 Solom SOLOMON-GAO Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:29:15 Solom SOLOMON-GAO Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2016/11/29:16:29:15 Solom SOLOMON-GAO Installing VBA Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:29:17 Solom SOLOMON-GAO Install VBA Runtime Succeeded
2016/11/29:16:29:17 Solom SOLOMON-GAO Installing VBA Runtime ENG Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:29:17 Solom SOLOMON-GAO Install VBA Runtime ENG Language Pack Succeeded
2016/11/29:16:29:17 Solom SOLOMON-GAO Installing VBA Runtime Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:29:17 Solom SOLOMON-GAO Install VBA Runtime Language Pack Succeeded
2016/11/29:16:29:18 Solom SOLOMON-GAO Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2016/11/29:16:30:30 Solom SOLOMON-GAO Download Complete CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2016/11/29:16:30:30 Solom SOLOMON-GAO Installing Autodesk® Material Library 2016 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:30:39 Solom SOLOMON-GAO Install Autodesk® Material Library 2016 - Low Image Library Succeeded
2016/11/29:16:30:39 Solom SOLOMON-GAO Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:30:41 Solom SOLOMON-GAO Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:30:41 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2016/11/29:16:30:45 Solom SOLOMON-GAO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2016/11/29:16:30:45 Solom SOLOMON-GAO Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:30:47 Solom SOLOMON-GAO Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:30:47 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/11/29:16:30:50 Solom SOLOMON-GAO Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/11/29:16:30:51 Solom SOLOMON-GAO Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/DIREC...
2016/11/29:16:30:55 Solom SOLOMON-GAO Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/DIREC...
2016/11/29:16:30:55 Solom SOLOMON-GAO Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/29:16:31:04 Solom SOLOMON-GAO Install DirectX Runtime Succeeded
2016/11/29:16:31:05 Solom SOLOMON-GAO Download Play DWGTRUEVIEW http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/DWGTR...
2016/11/29:16:32:37 Solom SOLOMON-GAO Download Complete DWGTRUEVIEW http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/DWGTR...
2016/11/29:16:32:37 Solom SOLOMON-GAO Installing Autodesk® DWG TrueView™ 2016 - English: USESETUPUNINSTALL=1 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Internet Explorer 7,SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,;;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:33:14 Solom SOLOMON-GAO Install Autodesk® DWG TrueView™ 2016 - English Succeeded
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {8D20B4D7-3422-4099-9332-39F27E617A6F} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {55D9E026-DCB0-46FF-B60A-68B972228CF6} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {450063AA-643B-417C-8CF5-405BA3F4EF40} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {106EC844-9F5E-4B72-BB3B-1E47D274A944} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {FACF203E-0F4D-489A-B80C-D185253C8FCB} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {1A2948E0-9445-42BE-9D01-472952F2657F} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {9A346205-EA92-4406-B1AB-50379DA3F057} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {C46C3C20-039E-4D7C-869F-9C0C05D65C06} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {577D60CB-0D5E-48D1-8850-84098AD34804} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {0576A3D0-0000-0409-0000-491C453655D7} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21} Failed
2016/11/29:16:33:14 Solom SOLOMON-GAO Uninstall {4780F600-0000-0409-0000-114715ACF216} Failed
2016/11/29:16:33:15 Solom SOLOMON-GAO Download Play ADR http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/ADR_e...
2016/11/29:16:33:25 Solom SOLOMON-GAO Download Complete ADR http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/ADR_e...
2016/11/29:16:33:25 Solom SOLOMON-GAO Installing Autodesk® Design Review 2013: ADSK_DESKTOPSHORTCUT_1=0 ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Internet Explorer 7,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.5 SP1,;;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:33:30 Solom SOLOMON-GAO Install Autodesk® Design Review 2013 Succeeded
2016/11/29:16:33:31 Solom SOLOMON-GAO Download Play INVENTOR http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/INVEN...
2016/11/29:16:37:37 Solom SOLOMON-GAO Download Complete INVENTOR http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/INVEN...
2016/11/29:16:37:37 Solom SOLOMON-GAO Installing Autodesk® Inventor® 2016: TRANSFORMS="C:\Autodesk\WI\Autodesk Inventor 2016\x64\en-us\Inventor\inventor.mst;C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:39:48 Solom SOLOMON-GAO Install Autodesk® Inventor® 2016 Succeeded
2016/11/29:16:39:48 Solom SOLOMON-GAO Download Play INVENTOR_en-us http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/INVEN...
2016/11/29:16:40:58 Solom SOLOMON-GAO Download Complete INVENTOR_en-us http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/INVEN...
2016/11/29:16:40:58 Solom SOLOMON-GAO Installing Autodesk® Inventor® 2016 Language Pack: TRANSFORMS="C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\_la6999.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:41:19 Solom SOLOMON-GAO Install Autodesk® Inventor® 2016 Language Pack Succeeded
2016/11/29:16:41:19 Solom SOLOMON-GAO Installing Eco Material Advisor: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:41:19 Solom SOLOMON-GAO Install Eco Material Advisor Succeeded
2016/11/29:16:41:20 Solom SOLOMON-GAO Download Play DCLIBRARY http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/DCLIB...
2016/11/29:16:45:57 Solom SOLOMON-GAO Download Complete DCLIBRARY http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/DCLIB...
2016/11/29:16:45:57 Solom SOLOMON-GAO Installing Autodesk® Inventor® Content Libraries: "C:\Autodesk\WI\Autodesk Inventor 2016\Content\DClibrary\DCLSetup.exe" INSTALLDIR="C:\ProgramData\Autodesk\Inventor 2016\" DC_ANSI=1 DC_DIN=1 DC_GOST=1 DC_ISO=1 DC_JISGB=1 DC_FEATURE=1 DC_OTHER=1 DC_PARKER=1 DC_RS=1 DC_SHEETM=1 DC_MOLD_MM=1 SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE="{8CB42675-2000-4FA1-AA77-40FCDFF783AF}" SETUP_ISLANGUAGEPACK="0" SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,;"
2016/11/29:16:47:41 Solom SOLOMON-GAO Install Autodesk® Inventor® Content Libraries Succeeded
2016/11/29:16:47:41 Solom SOLOMON-GAO Installing FARO LS 5.3.3.38662: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:47:45 Solom SOLOMON-GAO Install FARO LS 5.3.3.38662 Succeeded
2016/11/29:16:47:45 Solom SOLOMON-GAO Download Play AUTODESK_RECAP http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/AUTOD...
2016/11/29:16:49:20 Solom SOLOMON-GAO Download Complete AUTODESK_RECAP http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/AUTOD...
2016/11/29:16:49:20 Solom SOLOMON-GAO Installing Autodesk® ReCap™ 2016: TRANSFORMS="C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\x64\RC2016\AutodeskReCap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" INSTALLDIR="C:\Program Files\Autodesk\Autodesk ReCap 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:49:33 Solom SOLOMON-GAO Install Autodesk® ReCap™ 2016 Succeeded
2016/11/29:16:49:35 Solom SOLOMON-GAO Download Play VCREDIST2012UPD3X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:49:38 Solom SOLOMON-GAO Download Complete VCREDIST2012UPD3X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:49:38 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2012 Update3 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD3\vcredist_x86.exe" /q /norestart /l C:\Users\Solom\AppData\Local\Temp\vcredist_x86_2012_upd3_60610.log
2016/11/29:16:49:39 Solom SOLOMON-GAO Install Microsoft Visual C++ 2012 Update3 Redistributable (x86) Succeeded
2016/11/29:16:49:40 Solom SOLOMON-GAO Download Play VCREDIST2012UPD3X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:49:42 Solom SOLOMON-GAO Download Complete VCREDIST2012UPD3X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/11/29:16:49:42 Solom SOLOMON-GAO Installing Microsoft Visual C++ 2012 Update3 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD3\vcredist_x64.exe" /q /norestart /l C:\Users\Solom\AppData\Local\Temp\vcredist_x64_2012_upd3_60610.log
2016/11/29:16:49:42 Solom SOLOMON-GAO Install Microsoft Visual C++ 2012 Update3 Redistributable (x64) Succeeded
2016/11/29:16:49:42 Solom SOLOMON-GAO Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:49:43 Solom SOLOMON-GAO Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Succeeded
2016/11/29:16:49:43 Solom SOLOMON-GAO Download Play VAULT http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VAULT...
2016/11/29:16:50:30 Solom SOLOMON-GAO Download Complete VAULT http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VAULT...
2016/11/29:16:50:30 Solom SOLOMON-GAO Installing Autodesk® Vault Basic 2016 (Client): TRANSFORMS="C:\Autodesk\WI\Autodesk Inventor 2016\x64\en-us\VE\Vault.mst;C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\x64\VE\Vault-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" INSTALLDIR="C:\Program Files\Autodesk\Vault Basic 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:51:16 Solom SOLOMON-GAO Install Autodesk® Vault Basic 2016 (Client) Succeeded
2016/11/29:16:51:17 Solom SOLOMON-GAO Download Play VAULT_en-us http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VAULT...
2016/11/29:16:51:22 Solom SOLOMON-GAO Download Complete VAULT_en-us http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VAULT...
2016/11/29:16:51:22 Solom SOLOMON-GAO Installing Autodesk® Vault Basic 2016 Language Pack: TRANSFORMS="C:\Users\Solom\AppData\Local\Temp\_AI3BE3.tmp\_laF04A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" INSTALLDIR="C:\Program Files\Autodesk\Vault Basic 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/11/29:16:51:25 Solom SOLOMON-GAO Install Autodesk® Vault Basic 2016 Language Pack Succeeded
2016/11/29:16:51:25 Solom SOLOMON-GAO Download Play ADAPPLICATIONMANAGER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/ADAPP...
2016/11/29:16:51:39 Solom SOLOMON-GAO Download Complete ADAPPLICATIONMANAGER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/ADAPP...
2016/11/29:16:51:39 Solom SOLOMON-GAO Installing Autodesk® Application Manager: "C:\Autodesk\WI\Autodesk Inventor 2016\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2016/11/29:16:52:10 Solom SOLOMON-GAO Install Autodesk® Application Manager Succeeded
2016/11/29:16:52:10 Solom SOLOMON-GAO Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SUCCE...
2016/11/29:16:52:11 Solom SOLOMON-GAO Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SUCCE...
2016/11/29:16:52:12 Solom SOLOMON-GAO PageOpen InstallCompleteDialog
2016/11/29:16:52:24 Solom SOLOMON-GAO === Setup ended ===
2017/3/29:12:53:46 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/3/29:12:53:46 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/3/29:12:53:46 Admin DESKTOP-3I16JB7 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2017/3/29:12:53:46 Admin DESKTOP-3I16JB7 Launch
2017/3/29:12:53:46 Admin DESKTOP-3I16JB7 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2017/3/29:12:53:46 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI97AD.tmp
2017/3/29:12:58:14 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/3/29:12:53:47 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/3/29:12:53:47 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/3/29:12:53:47 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI97AD.tmp
2017/3/29:12:53:47 Admin DESKTOP-3I16JB7 Launch
2017/3/29:12:54:55 Admin DESKTOP-3I16JB7 Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:12:54:58 Admin DESKTOP-3I16JB7 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:12:54:59 Admin DESKTOP-3I16JB7 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:12:58:12 Admin DESKTOP-3I16JB7 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:12:58:13 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/3/29:13:10:46 Admin DESKTOP-3I16JB7 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AI97AD.tmp\Setup\AcadeUI.dll
2017/3/29:13:10:46 Admin DESKTOP-3I16JB7 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 PageOpen ProductInfoDialog
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 PageOpen InventorFlavorSelectionDialog
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==DefaultLanguage: en-us
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==InstallName: INVENTOR
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==ProductName: Autodesk Inventor 2016
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==DisplayName: Autodesk® Inventor® 2016
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==DeploymentName:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==SetupTitle: Autodesk Inventor 2016
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==ConfigTransform:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==ExeParams:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==SupportLink:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==InfotainmentLink:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==MsiFileName: inventor.msi
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==AdminImageConfigName: Imgx64
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==AdminImageRoot:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==GetBaseDeploymentName:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==DeploymentLocation:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==InstallDeploymentShortcut:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==ModifyDeploymentShortcut:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==SetupLockType: 2
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==SetupNetworkType: 1
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==SystemLocale: 1033
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==EvalMsiFilePath: C:\Users\Admin\AppData\Local\Temp\_AI97AD.tmp\SetupRes\eval.msi
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==InstallLogPath: C:\Users\Admin\AppData\Local\Temp\Inventor2016Install.log
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==ConfigFile: C:\Users\Admin\AppData\Local\Temp\_AI97AD.tmp\Setup.ini
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==SetupPath: C:\Users\Admin\AppData\Local\Temp\_AI97AD.tmp\
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==NetworkLogPath:
2017/3/29:13:10:59 Admin DESKTOP-3I16JB7 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2017/3/29:13:11:10 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/3/29:13:11:10 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/3/29:13:12:40 Admin DESKTOP-3I16JB7 PageOpen FullProgressDialog
2017/3/29:13:12:42 Admin DESKTOP-3I16JB7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/3/29:13:12:42 Admin DESKTOP-3I16JB7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/3/29:13:12:43 Admin DESKTOP-3I16JB7 Download Play VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:13:12:53 Admin DESKTOP-3I16JB7 Download Complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:13:12:53 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2017/3/29:13:14:16 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2017/3/29:13:14:17 Admin DESKTOP-3I16JB7 Download Play VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:13:14:21 Admin DESKTOP-3I16JB7 Download Complete VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:13:14:21 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2017/3/29:15:26:55 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2017/3/29:15:26:56 Admin DESKTOP-3I16JB7 Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:26:58 Admin DESKTOP-3I16JB7 Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:26:58 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2010.log
2017/3/29:15:27:03 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/3/29:15:27:04 Admin DESKTOP-3I16JB7 Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:27:06 Admin DESKTOP-3I16JB7 Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:27:06 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2010.log
2017/3/29:15:27:10 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/3/29:15:27:10 Admin DESKTOP-3I16JB7 Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:27:12 Admin DESKTOP-3I16JB7 Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:27:12 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/3/29:15:27:20 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/3/29:15:27:21 Admin DESKTOP-3I16JB7 Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:27:22 Admin DESKTOP-3I16JB7 Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:15:27:22 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/3/29:15:27:23 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/3/29:15:27:24 Admin DESKTOP-3I16JB7 Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2017/3/29:15:27:33 Admin DESKTOP-3I16JB7 Download Complete CM http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CM.ta...
2017/3/29:15:27:33 Admin DESKTOP-3I16JB7 Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/29:15:27:43 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 Succeeded
2017/3/29:15:27:43 Admin DESKTOP-3I16JB7 Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILB...
2017/3/29:15:27:52 Admin DESKTOP-3I16JB7 Download Complete CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILB...
2017/3/29:15:27:52 Admin DESKTOP-3I16JB7 Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/29:15:27:58 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2017/3/29:15:27:58 Admin DESKTOP-3I16JB7 Installing VBA Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/29:15:28:00 Admin DESKTOP-3I16JB7 Install VBA Runtime Succeeded
2017/3/29:15:28:00 Admin DESKTOP-3I16JB7 Installing VBA Runtime ENG Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/29:15:28:01 Admin DESKTOP-3I16JB7 Install VBA Runtime ENG Language Pack Succeeded
2017/3/29:15:28:01 Admin DESKTOP-3I16JB7 Installing VBA Runtime Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2016" SETUP_PACKAGECODE={8CB42675-2000-4FA1-AA77-40FCDFF783AF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={885CB096-0DBB-411F-AE76-39C6C0B5929C} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/29:15:28:01 Admin DESKTOP-3I16JB7 Install VBA Runtime Language Pack Succeeded
2017/3/29:15:28:01 Admin DESKTOP-3I16JB7 Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/3/29:15:28:34 Admin DESKTOP-3I16JB7 Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/3/29:15:28:34 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/29:15:28:35 Admin DESKTOP-3I16JB7 PageOpen InstallCompleteDialog
2017/3/29:16:17:05 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/3/29:16:17:41 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/3/29:16:17:41 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/3/29:16:17:41 Admin DESKTOP-3I16JB7 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2017/3/29:16:17:41 Admin DESKTOP-3I16JB7 Launch
2017/3/29:16:17:41 Admin DESKTOP-3I16JB7 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2017/3/29:16:17:41 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI48A5.tmp
2017/3/29:16:17:42 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/3/29:16:17:42 Admin DESKTOP-3I16JB7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:16:17:42 Admin DESKTOP-3I16JB7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:16:17:42 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/3/29:16:17:48 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message:
2017/3/29:16:17:48 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/3/29:16:17:48 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/3/29:16:17:51 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/3/29:16:17:51 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/3/29:16:17:53 Admin DESKTOP-3I16JB7 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AI48A5.tmp\Setup\AcadeUI.dll
2017/3/29:16:17:53 Admin DESKTOP-3I16JB7 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 PageOpen ProductInfoDialog
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 PageOpen InventorFlavorSelectionDialog
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==DefaultLanguage: en-us
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==InstallName: INVENTOR
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==ProductName: Autodesk Inventor 2016
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==DisplayName: Autodesk® Inventor® 2016
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==DeploymentName:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==SetupTitle: Autodesk Inventor 2016
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==ConfigTransform:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==ExeParams:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==SupportLink:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==InfotainmentLink:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==MsiFileName: inventor.msi
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==AdminImageConfigName: Imgx64
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==AdminImageRoot:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==GetBaseDeploymentName:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==DeploymentLocation:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==InstallDeploymentShortcut:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==ModifyDeploymentShortcut:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==SetupLockType: 2
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==SetupNetworkType: 1
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==SystemLocale: 1033
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==EvalMsiFilePath: C:\Users\Admin\AppData\Local\Temp\_AI48A5.tmp\SetupRes\eval.msi
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==InstallLogPath: C:\Users\Admin\AppData\Local\Temp\Inventor2016Install.log
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==ConfigFile: C:\Users\Admin\AppData\Local\Temp\_AI48A5.tmp\Setup.ini
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==SetupPath: C:\Users\Admin\AppData\Local\Temp\_AI48A5.tmp\
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==NetworkLogPath:
2017/3/29:16:18:01 Admin DESKTOP-3I16JB7 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2017/3/29:16:18:33 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/3/29:16:18:33 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/3/29:16:18:41 Admin DESKTOP-3I16JB7 PageOpen FullProgressDialog
2017/3/29:16:18:42 Admin DESKTOP-3I16JB7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/3/29:16:18:42 Admin DESKTOP-3I16JB7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/3/29:16:18:42 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:16:18:42 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/3/29:16:18:43 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/3/29:16:18:43 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:16:18:43 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/3/29:16:18:43 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/3/29:16:18:43 Admin DESKTOP-3I16JB7 Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/3/29:16:19:30 Admin DESKTOP-3I16JB7 Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/3/29:16:19:30 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/29:16:19:30 Admin DESKTOP-3I16JB7 PageOpen InstallCompleteDialog
2017/3/29:16:19:34 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/3/29:16:20:41 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/3/29:16:20:41 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/3/29:16:20:41 Admin DESKTOP-3I16JB7 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2017/3/29:16:20:41 Admin DESKTOP-3I16JB7 Launch
2017/3/29:16:20:41 Admin DESKTOP-3I16JB7 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2017/3/29:16:20:41 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI719.tmp
2017/3/29:16:20:42 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/3/29:16:20:42 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/3/29:16:20:42 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI719.tmp
2017/3/29:16:20:42 Admin DESKTOP-3I16JB7 Launch
2017/3/29:16:20:42 Admin DESKTOP-3I16JB7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:16:20:42 Admin DESKTOP-3I16JB7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/3/29:16:20:42 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/3/29:16:20:45 Admin DESKTOP-3I16JB7 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AI719.tmp\Setup\AcadeUI.dll
2017/3/29:16:20:45 Admin DESKTOP-3I16JB7 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 PageOpen ProductInfoDialog
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 PageOpen InventorFlavorSelectionDialog
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==DefaultLanguage: en-us
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==InstallName: INVENTOR
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==ProductName: Autodesk Inventor 2016
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==DisplayName: Autodesk® Inventor® 2016
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==DeploymentName:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==SetupTitle: Autodesk Inventor 2016
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==ConfigTransform:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==ExeParams:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==SupportLink:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==InfotainmentLink:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==MsiFileName: inventor.msi
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==AdminImageConfigName: Imgx64
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==AdminImageRoot:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==GetBaseDeploymentName:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==DeploymentLocation:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==InstallDeploymentShortcut:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==ModifyDeploymentShortcut:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==SetupLockType: 2
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==SetupNetworkType: 1
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==SystemLocale: 1033
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==EvalMsiFilePath: C:\Users\Admin\AppData\Local\Temp\_AI719.tmp\SetupRes\eval.msi
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==InstallLogPath: C:\Users\Admin\AppData\Local\Temp\Inventor2016Install.log
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==ConfigFile: C:\Users\Admin\AppData\Local\Temp\_AI719.tmp\Setup.ini
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==SetupPath: C:\Users\Admin\AppData\Local\Temp\_AI719.tmp\
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==NetworkLogPath:
2017/3/29:16:20:54 Admin DESKTOP-3I16JB7 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2017/3/29:16:20:56 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/3/29:16:20:56 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/3/29:16:21:01 Admin DESKTOP-3I16JB7 PageOpen FullProgressDialog
2017/3/29:16:21:01 Admin DESKTOP-3I16JB7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/3/29:16:21:02 Admin DESKTOP-3I16JB7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/3/29:16:21:02 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:16:21:02 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/3/29:16:21:02 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/3/29:16:21:02 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/3/29:16:21:02 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/3/29:16:21:03 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/3/29:16:21:03 Admin DESKTOP-3I16JB7 Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/3/29:16:21:49 Admin DESKTOP-3I16JB7 Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/3/29:16:21:49 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/29:16:21:49 Admin DESKTOP-3I16JB7 PageOpen InstallCompleteDialog
2017/3/29:16:24:51 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/3:12:26:24 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/4/3:12:26:24 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/4/3:12:26:24 Admin DESKTOP-3I16JB7 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2017/4/3:12:26:24 Admin DESKTOP-3I16JB7 Launch
2017/4/3:12:26:24 Admin DESKTOP-3I16JB7 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2017/4/3:12:26:24 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI5DDA.tmp
2017/4/3:12:26:26 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/3:12:26:25 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/4/3:12:26:25 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/4/3:12:26:25 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI5DDA.tmp
2017/4/3:12:26:25 Admin DESKTOP-3I16JB7 Launch
2017/4/3:12:26:25 Admin DESKTOP-3I16JB7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/3:12:26:25 Admin DESKTOP-3I16JB7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/3:12:26:26 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/4/3:12:26:44 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Prereq_8 SetupMode:7 InstallState:1 InstallAction:0 Message:
2017/4/3:12:26:44 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/4/3:12:26:44 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/4/3:12:26:47 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/4/3:12:26:47 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/4/3:12:26:49 Admin DESKTOP-3I16JB7 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AI5DDA.tmp\Setup\AcadeUI.dll
2017/4/3:12:26:49 Admin DESKTOP-3I16JB7 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2017/4/3:12:27:00 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/4/3:12:27:00 Admin DESKTOP-3I16JB7 PageOpen ProductInfoDialog
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 PageOpen InventorFlavorSelectionDialog
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==DefaultLanguage: en-us
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==InstallName: INVENTOR
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==ProductName: Autodesk Inventor 2016
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==DisplayName: Autodesk® Inventor® 2016
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==DeploymentName:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==SetupTitle: Autodesk Inventor 2016
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==ConfigTransform:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==ExeParams:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==SupportLink:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==InfotainmentLink:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==MsiFileName: inventor.msi
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==AdminImageConfigName: Imgx64
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==AdminImageRoot:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==GetBaseDeploymentName:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==DeploymentLocation:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==InstallDeploymentShortcut:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==ModifyDeploymentShortcut:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==SetupLockType: 2
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==SetupNetworkType: 1
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==SystemLocale: 1033
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==EvalMsiFilePath: C:\Users\Admin\AppData\Local\Temp\_AI5DDA.tmp\SetupRes\eval.msi
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==InstallLogPath: C:\Users\Admin\AppData\Local\Temp\Inventor2016Install.log
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==ConfigFile: C:\Users\Admin\AppData\Local\Temp\_AI5DDA.tmp\Setup.ini
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==SetupPath: C:\Users\Admin\AppData\Local\Temp\_AI5DDA.tmp\
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==NetworkLogPath:
2017/4/3:12:27:01 Admin DESKTOP-3I16JB7 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2017/4/3:12:27:47 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/4/3:12:27:47 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/4/3:12:28:00 Admin DESKTOP-3I16JB7 PageOpen FullProgressDialog
2017/4/3:12:28:01 Admin DESKTOP-3I16JB7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/3:12:28:01 Admin DESKTOP-3I16JB7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/3:12:28:01 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/3:12:28:01 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/4/3:12:28:09 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/4/3:12:28:09 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/3:12:28:09 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/4/3:12:28:18 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/4/3:12:28:19 Admin DESKTOP-3I16JB7 Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/3:12:29:04 Admin DESKTOP-3I16JB7 Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/3:12:29:04 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2017/4/3:12:29:05 Admin DESKTOP-3I16JB7 PageOpen InstallCompleteDialog
2017/4/3:12:33:38 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/3:12:34:32 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/4/3:12:34:32 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/4/3:12:34:32 Admin DESKTOP-3I16JB7 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2017/4/3:12:34:32 Admin DESKTOP-3I16JB7 Launch
2017/4/3:12:34:32 Admin DESKTOP-3I16JB7 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2017/4/3:12:34:32 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AICFFB.tmp
2017/4/3:12:34:34 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/3:12:34:33 Admin DESKTOP-3I16JB7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/3:12:34:34 Admin DESKTOP-3I16JB7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/3:12:34:34 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/4/3:12:34:39 Admin DESKTOP-3I16JB7 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AICFFB.tmp\Setup\AcadeUI.dll
2017/4/3:12:34:39 Admin DESKTOP-3I16JB7 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 PageOpen ProductInfoDialog
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 PageOpen InventorFlavorSelectionDialog
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==DefaultLanguage: en-us
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==InstallName: INVENTOR
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==ProductName: Autodesk Inventor 2016
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==DisplayName: Autodesk® Inventor® 2016
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==DeploymentName:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==SetupTitle: Autodesk Inventor 2016
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==ConfigTransform:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==ExeParams:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==SupportLink:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==InfotainmentLink:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==MsiFileName: inventor.msi
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==AdminImageConfigName: Imgx64
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==AdminImageRoot:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==GetBaseDeploymentName:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==DeploymentLocation:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==InstallDeploymentShortcut:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==ModifyDeploymentShortcut:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==SetupLockType: 2
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==SetupNetworkType: 1
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==SystemLocale: 1033
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==EvalMsiFilePath: C:\Users\Admin\AppData\Local\Temp\_AICFFB.tmp\SetupRes\eval.msi
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==InstallLogPath: C:\Users\Admin\AppData\Local\Temp\Inventor2016Install.log
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==ConfigFile: C:\Users\Admin\AppData\Local\Temp\_AICFFB.tmp\Setup.ini
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==SetupPath: C:\Users\Admin\AppData\Local\Temp\_AICFFB.tmp\
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==NetworkLogPath:
2017/4/3:12:34:47 Admin DESKTOP-3I16JB7 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2017/4/3:12:34:54 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/4/3:12:34:54 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/4/3:12:35:07 Admin DESKTOP-3I16JB7 PageOpen FullProgressDialog
2017/4/3:12:35:08 Admin DESKTOP-3I16JB7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/3:12:35:09 Admin DESKTOP-3I16JB7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/3:12:35:09 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/3:12:35:09 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/4/3:12:35:09 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/4/3:12:35:10 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/3:12:35:10 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/4/3:12:35:10 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/4/3:12:35:11 Admin DESKTOP-3I16JB7 Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/3:12:36:30 Admin DESKTOP-3I16JB7 Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/3:12:36:30 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2017/4/3:12:36:30 Admin DESKTOP-3I16JB7 PageOpen InstallCompleteDialog
2017/4/3:12:39:43 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/4:14:50:42 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/4/4:14:50:42 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/4/4:14:50:42 Admin DESKTOP-3I16JB7 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2017/4/4:14:50:42 Admin DESKTOP-3I16JB7 Launch
2017/4/4:14:50:42 Admin DESKTOP-3I16JB7 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2017/4/4:14:50:42 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI6A62.tmp
2017/4/4:14:50:45 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/4:14:50:43 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/4/4:14:50:43 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/4/4:14:50:43 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI6A62.tmp
2017/4/4:14:50:43 Admin DESKTOP-3I16JB7 Launch
2017/4/4:14:50:44 Admin DESKTOP-3I16JB7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/4:14:50:44 Admin DESKTOP-3I16JB7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/4:14:50:45 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/4/4:14:50:48 Admin DESKTOP-3I16JB7 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AI6A62.tmp\Setup\AcadeUI.dll
2017/4/4:14:50:48 Admin DESKTOP-3I16JB7 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 PageOpen ProductInfoDialog
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 PageOpen InventorFlavorSelectionDialog
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==DefaultLanguage: en-us
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==InstallName: INVENTOR
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==ProductName: Autodesk Inventor 2016
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==DisplayName: Autodesk® Inventor® 2016
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==DeploymentName:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==SetupTitle: Autodesk Inventor 2016
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==ConfigTransform:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==ExeParams:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==SupportLink:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==InfotainmentLink:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==MsiFileName: inventor.msi
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==AdminImageConfigName: Imgx64
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==AdminImageRoot:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==GetBaseDeploymentName:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==DeploymentLocation:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==InstallDeploymentShortcut:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==ModifyDeploymentShortcut:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==SetupLockType: 2
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==SetupNetworkType: 1
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==SystemLocale: 1033
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==EvalMsiFilePath: C:\Users\Admin\AppData\Local\Temp\_AI6A62.tmp\SetupRes\eval.msi
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==InstallLogPath: C:\Users\Admin\AppData\Local\Temp\Inventor2016Install.log
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==ConfigFile: C:\Users\Admin\AppData\Local\Temp\_AI6A62.tmp\Setup.ini
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==SetupPath: C:\Users\Admin\AppData\Local\Temp\_AI6A62.tmp\
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==NetworkLogPath:
2017/4/4:14:51:01 Admin DESKTOP-3I16JB7 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2017/4/4:14:51:02 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/4/4:14:51:03 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/4/4:14:51:06 Admin DESKTOP-3I16JB7 PageOpen FullProgressDialog
2017/4/4:14:51:07 Admin DESKTOP-3I16JB7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/4:14:51:07 Admin DESKTOP-3I16JB7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/4:14:51:08 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/4:14:51:08 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/4/4:14:51:16 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/4/4:14:51:16 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/4:14:51:16 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/4/4:14:51:23 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/4/4:14:51:23 Admin DESKTOP-3I16JB7 Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/4:14:52:43 Admin DESKTOP-3I16JB7 Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/4:14:52:43 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2017/4/4:14:52:43 Admin DESKTOP-3I16JB7 PageOpen InstallCompleteDialog
2017/4/4:14:57:18 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/4:15:34:38 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/4/4:15:34:38 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/4/4:15:34:38 Admin DESKTOP-3I16JB7 Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2017/4/4:15:34:38 Admin DESKTOP-3I16JB7 Launch
2017/4/4:15:34:38 Admin DESKTOP-3I16JB7 CommandLine /PK 797H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set..."
2017/4/4:15:34:38 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AIA352.tmp
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 === Setup ended ===
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 === Setup started on DESKTOP-3I16JB7 by Admin ===
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 Path_Length: 154
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 Current Directory C:\Users\Admin\AppData\Local\Temp\_AIA352.tmp
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 Launch
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2017/4/4:15:34:39 Admin DESKTOP-3I16JB7 PageOpen LaunchDialog
2017/4/4:15:34:45 Admin DESKTOP-3I16JB7 Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\Admin\AppData\Local\Temp\_AIA352.tmp\Setup\AcadeUI.dll
2017/4/4:15:34:45 Admin DESKTOP-3I16JB7 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 PageOpen LicenseDialog
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 PageOpen ProductInfoDialog
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 PageOpen InventorFlavorSelectionDialog
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==DefaultLanguage: en-us
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==InstallName: INVENTOR
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==ProductName: Autodesk Inventor 2016
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==DisplayName: Autodesk® Inventor® 2016
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==DeploymentName:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==SetupTitle: Autodesk Inventor 2016
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==ConfigTransform:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==ExeParams:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==SupportLink:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==InfotainmentLink:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==MsiFileName: inventor.msi
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==AdminImageConfigName: Imgx64
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==AdminImageRoot:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==GetBaseDeploymentName:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==DeploymentLocation:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==InstallDeploymentShortcut:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==ModifyDeploymentShortcut:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==SetupLockType: 2
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==SetupNetworkType: 1
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==SystemLocale: 1033
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==EvalMsiFilePath: C:\Users\Admin\AppData\Local\Temp\_AIA352.tmp\SetupRes\eval.msi
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==InstallLogPath: C:\Users\Admin\AppData\Local\Temp\Inventor2016Install.log
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==ConfigFile: C:\Users\Admin\AppData\Local\Temp\_AIA352.tmp\Setup.ini
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==SetupPath: C:\Users\Admin\AppData\Local\Temp\_AIA352.tmp\
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==NetworkLogPath:
2017/4/4:15:34:52 Admin DESKTOP-3I16JB7 Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2017/4/4:15:34:55 Admin DESKTOP-3I16JB7 Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2017/4/4:15:34:55 Admin DESKTOP-3I16JB7 PageOpen ProductSelectionDialog2
2017/4/4:15:35:05 Admin DESKTOP-3I16JB7 PageOpen FullProgressDialog
2017/4/4:15:35:06 Admin DESKTOP-3I16JB7 Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/4:15:35:07 Admin DESKTOP-3I16JB7 Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2017/4/4:15:35:07 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/4:15:35:07 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/4/4:15:35:07 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/4/4:15:35:07 Admin DESKTOP-3I16JB7 Download Skipped VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2017/4/4:15:35:07 Admin DESKTOP-3I16JB7 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Admin\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/4/4:15:35:08 Admin DESKTOP-3I16JB7 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/4/4:15:35:08 Admin DESKTOP-3I16JB7 Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/4:15:35:51 Admin DESKTOP-3I16JB7 Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2017/4/4:15:35:51 Admin DESKTOP-3I16JB7 Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
I need it for school so it's really important and I just want to ask if anyone can help me. That would really be a big thank.
mcgyvr
Did you use the "Install Now" method?.. If so.. DON'T.. Use the browser download method instead and download all the files and install from that..
Mark.Lancaster
@Anonymous
Welcome to the community...
Your installation is simply failing due to the method (web installer) you're using.  This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
